Maggio 21, 2013, 04:05:00 am *
Autore Discussione: 2010 non si installa  (Letto 3867 volte)
gengar
« inserita:: Dicembre 19, 2009, 03:55:35 pm »
non ho modo di insatllare la 2010 FREE sul mio pc (dove è già installata una 2009.1 abbastanza personalizzata)
dopo la configurazione della lingua ( tutto normale sino ad ora ) l'installazione si blocca con questi errori a video
non potendo usare il copiia/incolla me li sono scritti a penna e mi scuso per qualche errore di trascrizione
SI E' VERIFICATO UN ERRORE
INTERNAL ERROR :. unknown device hdc
MDK::Common::Various::internal_error() called  from /usr/lib/libDrakX/device.pm:176
devices::entry() called  from /usr/lib/libDrakX/device.pm:191
devices::make() called from /usr//lib/libDrakX/fsedit.pm:127
Fsedit::handle_-dmraid() called from /usr/lib/libDrakX/fsedit.pm:166
fsedit::get_hds() called from /usr/lib/libDrakX/fs/any.pm:13
fs::any::get_hds() called from /usr/lib/libDrakX/install/any.pm:1056
install::any::get_hds() called from /usr/lib/libDrakX/install/steps_interactive.pm:262
install::steps_interactive::setupSCSI() called from /usr/lib/libDrakX/install/install2.pm:83
install::install2::installStepsCall() called from /usr/lib/libDrakX/install2.pm::119
install::install2::setupSCSI() called from /usr/lib/libDrakX/install2.pm:586
(EVAL)() called from /usr/lib/libDrakX/install2.pm:585
install::install2::manin() called from /usr/bin/install2:30
[root@spearow gengar]# lspci
00:00.0 RAM memory: nVidia Corporation MCP61 Memory Controller (rev a1)
00:01.0 ISA bridge: nVidia Corporation MCP61 LPC Bridge (rev a2)
00:01.1 SMBus: nVidia Corporation MCP61 SMBus (rev a2)
00:01.2 RAM memory: nVidia Corporation MCP61 Memory Controller (rev a2)
00:02.0 USB Controller: nVidia Corporation MCP61 USB Controller (rev a2)
00:02.1 USB Controller: nVidia Corporation MCP61 USB Controller (rev a2)
00:04.0 PCI bridge: nVidia Corporation MCP61 PCI bridge (rev a1)
00:05.0 Audio device: nVidia Corporation MCP61 High Definition Audio (rev a2)
00:06.0 IDE interface: nVidia Corporation MCP61 IDE (rev a2)
00:08.0 IDE interface: nVidia Corporation MCP61 SATA Controller (rev a2)
00:09.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
00:0b.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
00:0c.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
00:0d.0 VGA compatible controller: nVidia Corporation GeForce 6100 nForce 405 (rev a2)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:06.0 RAID bus controller: Integrated Technology Express, Inc. IT/ITE8212 Dual channel ATA RAID controller (rev 13)
[root@spearow gengar]# lsusb
Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 004: ID 0409:0059 NEC Corp. HighSpeed Hub
Bus 002 Device 003: ID 062a:0102 Creative Labs
Bus 002 Device 002: ID 0c45:6130 Microdia PC Camera (SN9C120)
a questo controller è collegato un hd da 20gb che uso da backup un samsung sv2042h
il dvd con cui installo è quello che ho trovato Linux Magazzine ma succede anche con le iso che avevo scaricato prima
pensa che ho installato la 2010 con VirtulaBox per vedere come funzionava e dopo un mese ho deciso di fare l'aggiornamento dato che non mi ha mai dato nessun problema
inoltte al controller principale della scheda madre sata ho due hd da 250 gb uno vuoto l'altro con la 2009.1
« Risposta #1 inserita:: Dicembre 20, 2009, 02:23:38 pm »
Hai verificato nella Errata di Mandriva se il tuo hardware rientra in un problema noto? ...in più, prova a passare qualche parametro al kernel all'atto dell'avvio, del tipo;
noacpi
noapic
etc, cambia qualcosa?
gengar
« Risposta #2 inserita:: Dicembre 20, 2009, 09:08:43 pm »
il mio hardware è supportatissimo dato che ha passato ormai 6 Mandriva e prima del tentativo di installare la 2010 funzionava alla meraviglia conunque ho risolto staccando l'hd da 20 gb che usavo come backup collegato ad una scheda IT/ITE8212 Dual channel ATA RAID
« Risposta #3 inserita:: Dicembre 20, 2009, 11:30:10 pm »
...cioè hai staccato solo l'hard disk e il tutto ha ripreso a funzionare?  Che?!? ...quindi la scheda è rimasta collegata all'hardware del PC?  Che?!?
gengar
« Risposta #4 inserita:: Dicembre 22, 2009, 05:57:00 pm »
si
« Risposta #5 inserita:: Dicembre 22, 2009, 11:47:36 pm »
...ma se ora ricolleghi l'hard disk funziona bene la distribuzione?  Occhi al cielo
gengar
« Risposta #6 inserita:: Dicembre 23, 2009, 09:13:05 pm »
per ora non ho ancora avuto l modo di provare per mancanza di tempo (tempo da lupi e lavoro)
durante le feste ti farò sapere anche xke ho anche altri problemi che devo risolvere non sò se dipenda dal I° disco o il controller SATA dopo un certo periodo il disco comincia a tichettare come se la testina sbatta a fine corsa , la schermata diventa grigia c il pc è bloccato sino a quando smette
« Risposta #7 inserita:: Dicembre 24, 2009, 09:45:00 am »
...il firmware del controller Che?!?
gengar
« Risposta #8 inserita:: Dicembre 24, 2009, 06:11:27 pm »
? non capisco
« Risposta #9 inserita:: Dicembre 25, 2009, 11:24:36 pm »
...ARGOS si chiedeva so potesse essere in qualche modo il firmware del controller; io penso di no perché la scheda non è stata scollegata. Quello che è stato scollegatto è solo l'hard disk collegato al controller....  Che?!?
gengar
« Risposta #10 inserita:: Dicembre 26, 2009, 11:34:37 pm »
forse mi sono spiegato male il tichettio che sento ( che blocca tutte le aioni cel mouse e della tastiera) non viene dal controller della scheda pci installata ma da uno degli HD collegati al controller SATA della scheda madre
gengar
« Risposta #11 inserita:: Dicembre 28, 2009, 02:43:04 pm »
ok ho ricollegato l'Hd ( il vecchio 20 gb per backup) al controllr IT/ITE8212 Dual channel ATA RAID aggiunto alla scheda madre su bus pci
 Mandriva funziona correttamente, HD è riconosciuto e funzionanate
non capisco i problemi in fase di installazione
« Risposta #12 inserita:: Dicembre 28, 2009, 05:31:00 pm »
...non viene dal controller della scheda pci installata ma da uno degli HD collegati al controller SATA della scheda madre
Già  Occhi al cielo , hai ragione non avevo capito, e non mi ero accorto del particolare descritto da MICHELE.P che staccando solo il HD, smetteva Ghigno ...
Allora credo che tra il controller della scheda madre e quello PCI c'è una incongruenza di trasferimento bus-data, cioè (scusa se non sono molto tecnico Ghigno , ma non è che me ne intenda più di tanto Ghigno ), mi riferisco alla differenza di frequenza tra il controller integrato alla scheda e il controller PCI, e qui bisognerebbe intervenire nel BIOS Linguaccia
In più, trattandosi di un HD di 20 Gb avrà qualche anneto sulle spalle Ghigno , per cui vedi anche la frequenza di trasferimento del HD di 20 Gb rispetto a i controllers sia quello integrato che quello PCI. Se la frequenza del HD è inferiore a quella del controller dovrebbe andare bene, se la cosa invece, è vice versa, cioè, la frequenza del controller è inferiore al quella del HD allora da problemi.
Da quello che scrivi, ho il sospetto che tu abbia aggiornato il hardware del PC di recente Occhiolino , e che (forze), hai bisogno solo di mettere a puntino alcuni parametri Occhiolino , sia al HD che nel BIOS Occhi al cielo , conosci HDparm ?  Sorriso :
http://en.wikipedia.org/wiki/Hdparm
Se qualcosa di quello che ho scritto prima risulta avere senso Felice , allora questa applicazione ti potrebbe anche risultare utile, ora che hai risolto Occhiolino
