Maggio 25, 2012, 03:25:34 am *
Autore Discussione: client ftp.tar.bz2  (Letto 1220 volte)
Maurizio1230
« inserita:: Luglio 12, 2006, 11:39:15 am »
Salve. Questo client ftp mi da il seguente errore dopo aver digitato make:
Good - your configure finished. Start make now
root:/home/Maurizio1230/Desktop/kftpgrabber-0.6.0 # make
make  all-recursive
make[1]: Entering directory `/home/Maurizio1230/Desktop/kftpgrabber-0.6.0\'
Making all in kftpgrabber
make[2]: Entering directory `/home/Maurizio1230/Desktop/kftpgrabber-0.6.0/kftpgrabber\'
Making all in src
make[3]: Entering directory `/home/Maurizio1230/Desktop/kftpgrabber-0.6.0/kftpgrabber/src\'
Making all in ftp
make[4]: Entering directory `/home/Maurizio1230/Desktop/kftpgrabber-0.6.0/kftpgrabber/src/ftp\'
/usr/lib/qt3/bin/moc ./kftpclientthread.h -o kftpclientthread.moc
if g++ -DHAVE_CONFIG_H -I. -I. -I../../.. -I../../../kftpgrabber/src -I../../../kftpgrabber/src/misc -I../../../kftpgrabber/src/misc/libs -I../../../kftpgrabber/src/widgets -I/opt/kde3/include -I/usr/lib/qt3/include -I/usr/X11R6/include   -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wno-non-virtual-dtor -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_CLEAN_NAMESPACE -DQT_NO_ASCII_CAST -DQT_NO_STL -DQT_NO_COMPAT -DQT_NO_TRANSLATION -fexceptions -MT kftpclientthread.o -MD -MP -MF \".deps/kftpclientthread.Tpo\" \\
  -c -o kftpclientthread.o `test -f \'kftpclientthread.cpp\' || echo \'./\'`kftpclientthread.cpp; \\
then mv -f \".deps/kftpclientthread.Tpo\" \".deps/kftpclientthread.Po\"; \\
else rm -f \".deps/kftpclientthread.Tpo\"; exit 1; \\
fi
if g++ -DHAVE_CONFIG_H -I. -I. -I../../.. -I../../../kftpgrabber/src -I../../../kftpgrabber/src/misc -I../../../kftpgrabber/src/misc/libs -I../../../kftpgrabber/src/widgets -I/opt/kde3/include -I/usr/lib/qt3/include -I/usr/X11R6/include   -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wno-non-virtual-dtor -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_CLEAN_NAMESPACE -DQT_NO_ASCII_CAST -DQT_NO_STL -DQT_NO_COMPAT -DQT_NO_TRANSLATION -fexceptions -MT kftpextensions.o -MD -MP -MF \".deps/kftpextensions.Tpo\" \\
  -c -o kftpextensions.o `test -f \'kftpextensions.cpp\' || echo \'./\'`kftpextensions.cpp; \\
then mv -f \".deps/kftpextensions.Tpo\" \".deps/kftpextensions.Po\"; \\
else rm -f \".deps/kftpextensions.Tpo\"; exit 1; \\
fi
/usr/lib/qt3/bin/moc ./socket.h -o socket.moc
if g++ -DHAVE_CONFIG_H -I. -I. -I../../.. -I../../../kftpgrabber/src -I../../../kftpgrabber/src/misc -I../../../kftpgrabber/src/misc/libs -I../../../kftpgrabber/src/widgets -I/opt/kde3/include -I/usr/lib/qt3/include -I/usr/X11R6/include   -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wno-non-virtual-dtor -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_CLEAN_NAMESPACE -DQT_NO_ASCII_CAST -DQT_NO_STL -DQT_NO_COMPAT -DQT_NO_TRANSLATION -fexceptions -MT socket.o -MD -MP -MF \".deps/socket.Tpo\" \\
  -c -o socket.o `test -f \'socket.cpp\' || echo \'./\'`socket.cpp; \\
then mv -f \".deps/socket.Tpo\" \".deps/socket.Po\"; \\
else rm -f \".deps/socket.Tpo\"; exit 1; \\
fi
../../../kftpgrabber/src/kftpqueue.h:131: error: extra qualification ‘KFTPQueueManager::’ on member ‘fileExistsDialog’
make[4]: *** [socket.o] Error 1
make[4]: Leaving directory `/home/Maurizio1230/Desktop/kftpgrabber-0.6.0/kftpgrabber/src/ftp\'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/Maurizio1230/Desktop/kftpgrabber-0.6.0/kftpgrabber/src\'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/Maurizio1230/Desktop/kftpgrabber-0.6.0/kftpgrabber\'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/Maurizio1230/Desktop/kftpgrabber-0.6.0\'
make: *** [all] Error 2
« Risposta #1 inserita:: Luglio 12, 2006, 12:47:59 pm »
...c\'è un errore nel codice sorgente oppure la versione del programma non è stata aggiornata al nuovo GCC...non vedo neanche il CVS altrimenti si potrebbe provare a scaricare da li l\'ultimo sviluppo...
Ad ogni modo se vuoi provare/trovare vari client FTP per ambiente KDE prova a questo indirizzo;
http://www.kde-apps.org/index.php?xcontentmode=236
Maurizio1230
« Risposta #2 inserita:: Luglio 12, 2006, 05:04:05 pm »
ho installato gftp da yast perchè tutti gli altri dopo make davano problemi. Comunque il client che ho installato funziona abbastanza bene
