Maggio 24, 2012, 07:35:11 pm *
Autore Discussione: [RISOLTO] Re: atheros AR9285 ubuntu 10.10 con kernel 3.1.1  (Letto 2954 volte)
Peps
« Risposta #15 inserita:: Novembre 30, 2011, 04:02:17 pm »
ecco lsmod del "kernel buono"
giuseppe@giuseppe-house:~$ lsmod
binfmt_misc             6042  1
pci_stub                 969  1
vboxpci                14931  0
vboxnetadp              6963  0
vboxnetflt             16998  0
vboxdrv               197334  3 vboxpci,vboxnetadp,vboxnetflt
nfsd                  233678  11
lockd                  63677  1 nfsd
nfs_acl                 1899  1 nfsd
auth_rpcgss            30182  1 nfsd
sunrpc                162007  12 nfsd,lockd,nfs_acl,auth_rpcgss
parport_pc             24136  0
ppdev                   4845  0
snd_hda_codec_hdmi     20248  1
snd_hda_codec_realtek   225854  1
snd_hda_intel          19481  2
snd_hda_codec          67421  3 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel
snd_hwdep               4618  1 snd_hda_codec
nvidia              10733952  42
snd_pcm                59766  3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_seq_midi            3976  0
arc4                    1118  2
snd_rawmidi            14659  1 snd_seq_midi
ath9k                  94377  0
snd_seq_midi_event      4608  1 snd_seq_midi
joydev                  8212  0
snd_seq                42187  2 snd_seq_midi,snd_seq_midi_event
snd_timer              15999  2 snd_pcm,snd_seq
snd_seq_device          4405  3 snd_seq_midi,snd_rawmidi,snd_seq
coretemp                4420  0
mac80211              232043  1 ath9k
ath9k_common            1672  1 ath9k
ath9k_hw              282945  2 ath9k,ath9k_common
ath                    11678  2 ath9k,ath9k_hw
uvcvideo               55178  0
agpgart                22305  1 nvidia
videodev               66367  1 uvcvideo
video                   9937  0
cfg80211              129601  3 ath9k,mac80211,ath
snd                    38805  14 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
psmouse                55224  0
soundcore                688  1 snd
snd_page_alloc          5869  2 snd_hda_intel,snd_pcm
i2c_nforce2             4392  0
lp                      6552  0
parport                25199  3 parport_pc,ppdev,lp
serio_raw               3488  0
usb_storage            35057  0
ahci                   18021  5
r8169                  34490  0
libahci                16512  1 ahci
mii                     3375  1 r8169
Peps
« Risposta #16 inserita:: Novembre 30, 2011, 05:10:14 pm »
ciao  Felice
ho risolto!!  Ghigno
ho installato il kernel 3.1.4 compilato da me ed avevo sempre lo stesso problema
ho usato i compat wireless 3.2 rc1 e adesso funziona tutto
ecco la soluzione
1) scaricare la versione compat wireless 3.2 da qua http://linuxwireless.org/en/users/Download/stable/
2)cd Scrivania
3) tar -xf compat-wireless-3.2-rc1-1.tar.bz2
4)cd compat-wireless-3.2-rc1-1
5)make
6)sudo make install
7)sudo reboot
per adesso va alla grande  Ghigno
alla prossima   Occhiolino
telebabbo
« Risposta #17 inserita:: Dicembre 19, 2011, 05:30:55 pm »
Il problema si risolve abilitando
Atheros ath9k PCI/PCIe bus support, (ATH9K_PCI=y)
che si trova in:
-> Device Drivers
-> Network device support (NETDEVICES [=y])
-> Wireless LAN (WLAN [=y])
-> Atheros Wireless Cards (ATH_COMMON [=y])
-> Atheros 802.11n wireless cards support (ATH9K [=y])
(a quanto pare questo modulo non è necessario per i kernel precedenti)
t.
Peps
« Risposta #18 inserita:: Gennaio 21, 2012, 09:35:13 pm »
ciao telebabbo
domani compilo l'ultimo kernel stable disponibile su kernel.org e ti dico che basta abilitare quello  Felice
a me così comunque funziona perfettamente
ti aggiorno
Peps
« Risposta #19 inserita:: Gennaio 23, 2012, 04:52:26 pm »
ciao telebabbo
ieri ho compilato il kernel 3.2.1 stable e ho aggiunto i moduli che hai detto tu.
Hai ragione adesso funziona senza i compat wireless  Occhiolino
grazie per l'info  Felice
possiamo dire RISOLTO IN DUE MODI  Occhi al cielo
alla prossima
« Ultima modifica: Gennaio 23, 2012, 04:54:11 pm da Peps » Registrato
