To: root
Subject: Panic or segfault in Samba
The Samba 'panic action' script, /usr/share/samba/panic-action,
was called for PID 2300 (/usr/sbin/smbd).
This means there was a problem with the program, such as a segfault.
Below is a backtrace for this process generated with gdb, which shows
the state of the program at the time the error occurred. The Samba log
files may contain additional information about the problem.
If the problem persists, you are encouraged to first install the
samba-dbg package, which contains the debugging symbols for the Samba
binaries. Then submit the provided information as a bug report to
Debian. For information about the procedure for submitting bug reports,
please see
http://www.debian.org/Bugs/Reporting or the reportbug(1)
manual page.
[Thread debugging using libthread_db enabled]
0x00007f6c53a45f7e in waitpid () from /lib/libc.so.6
#0 0x00007f6c53a45f7e in waitpid () from /lib/libc.so.6
#1 0x00007f6c539dd7e9 in ?? () from /lib/libc.so.6
#2 0x00007f6c5722da44 in smb_panic ()
#3 0x00007f6c5721d02d in ?? ()
#4 <signal handler called>
#5 0x00007f6c53a1f052 in ?? () from /lib/libc.so.6
#6 0x00007f6c5720737e in rep_strlcpy ()
#7 0x00007f6c5723ada4 in connections_fetch_entry ()
#8 0x00007f6c56fe4996 in yield_connection ()
#9 0x00007f6c5704ef07 in close_cnum ()
#10 0x00007f6c5700910d in reply_tdis ()
#11 0x00007f6c5704dbc3 in ?? ()
#12 0x00007f6c5704e016 in ?? ()
#13 0x00007f6c5704e90d in ?? ()
#14 0x00007f6c5723d642 in run_events ()
#15 0x00007f6c5704d508 in smbd_process ()
#16 0x00007f6c574bd53b in ?? ()
#17 0x00007f6c5723d642 in run_events ()
#18 0x00007f6c5723d8c1 in ?? ()
#19 0x00007f6c5723dca0 in _tevent_loop_once ()
#20 0x00007f6c574be00b in main ()
A debugging session is active.
Inferior 1 [process 2300] will be detached.
Quit anyway? (y or n) [answered Y; input not from terminal]
mi è venuto in mente che quando usavo SuseLinux spesso l'utente root riceveva dei messaggi su ciò che non andava, non ricordavo la directory dove venivano mandati i messaggi ma sotto LinuxMint mi sono trovato sulla directory di /root/dead.letter
per me incomprensibile per carenze informatiche...
