mmm
ho fatto qualche prova ma non riesco...
io dovrei aggiungere due sistemi operativi,uno su /dev/sda6 slackware e un altro su /dev/sda4 backbox e poi il terzo sistema operativo è debian su /dev/sda5
e questo è il mio lilo.conf:
# Automatically added by lilo postinst script
large-memory
# /etc/lilo.conf - See: `lilo(8)' and `lilo.conf(5)',
# --------------- `install-mbr(8)', `/usr/share/doc/lilo/',
# and `/usr/share/doc/mbr/'.
# | !! Reminder !! |
# | Don't forget to run `lilo' after you make changes to this |
# | conffile, `/boot/bootmess.txt' (if you have created it), or |
# | install a new kernel. The computer will most likely fail to |
# | boot if a kernel-image post-install script or you don't |
# | remember to run `lilo'. |
# Specifies the boot device. This is where Lilo installs its boot
# case it installs in the MBR, and will overwrite the current MBR.
#boot=/dev/sda
boot = /dev/disk/by-id/ata-HTS541010G9SA00_MP2ZX0X0KN5EBS
# Specifies the device that should be mounted as root. (`/')
# root = /dev/sda5
root = "UUID=f3001dfa-9cf8-447d-877e-40be09ef8e6c"
# This option may be needed for some software RAID installs.
# raid-extra-boot=mbr-only
# Enable map compaction:
# Tries to merge read requests for adjacent sectors into a single
# read request. This drastically reduces load time and keeps the
# because it doesn't always work.
# compact
# Installs the specified file as the new boot sector
# You have the choice between: text, bmp, and menu
# Look in lilo.conf(5) manpage for details
#install=menu
# Specifies the location of the map file
map=/boot/map
# You can set a password here, and uncomment the `restricted' lines
# in the image definitions below to make it so that a password must
# be typed to boot anything but a default configuration. If a
# command line is given, other than one specified by an `append'
# statement in `lilo.conf', the password will be required, but a
# standard default boot will not require one.
# This will, for instance, prevent anyone with access to the
# console from booting with something like `Linux init=/bin/sh',
# and thus becoming `root' without proper authorization.
# Note that if you really need this type of security, you will
# likely also want to use `install-mbr' to reconfigure the MBR
# program, as well as set up your BIOS to disallow booting from
# removable disk or CD-ROM, then put a password on getting into the
# BIOS configuration as well. Please RTFM `install-mbr(8)'.
# password=tatercounter2000
# Specifies the number of deciseconds (0.1 seconds) LILO should
# wait before booting the first image.
delay=20
# You can put a customized boot message up if you like. If you use
# `prompt', and this computer may need to reboot unattended, you
# must specify a `timeout', or it will sit there forever waiting
# for a keypress. `single-key' goes with the `alias' lines in the
# `image' configurations below. eg: You can press `1' to boot
# `Linux', `2' to boot `LinuxOLD', if you uncomment the `alias'.
# message=/boot/bootmess.txt
# prompt
# delay=100
# timeout=100
# Specifies the VGA text mode at boot time. (normal, extended, ask, <mode>)
# vga=ask
# vga=9
# Kernel command line options that apply to all installed images go
# here. See: The `boot-prompt-HOWTO' and `kernel-parameters.txt' in
# the Linux kernel `Documentation' directory.
# append=""
# If you used a serial console to install Debian, this option should be
# enabled by default.
# serial=
# Boot up Linux by default.
default=Linux
image=/vmlinuz
label=Linux
read-only
# restricted
# alias=1
append="quiet"
initrd=/initrd.img
image=/vmlinuz.old
label=LinuxOLD
read-only
optional
# restricted
# alias=2
append="quiet"
initrd=/initrd.img.old
# If you have another OS on this machine to boot, you can uncomment the
# following lines, changing the device name on the `other' line to
# where your other OS' partition is.
# other=/dev/sda6
# label=Slackware
# restricted
# alias=3
avevo provato a configurare l'ultima parte ma dando /sbin/lilo mi dava errore...
