Maggio 24, 2012, 06:53:51 pm *
Autore Discussione: [RISOLTO]scheda tv digitale terrestre+sat (variazione scheda)  (Letto 4260 volte)
« Risposta #15 inserita:: Novembre 11, 2011, 02:58:01 pm »
Ok, allora rimaniamo in attesa di informazioni a riguardo...
trimix
« Risposta #16 inserita:: Novembre 19, 2011, 05:31:18 pm »
ciao a tutti...sono tornato ieri dalla trasferta....percui....se per voi va bene riprendo da dove mi ero fermato...
robi@robi-desktop:~/Scrivania$ lsmod
tda1004x               22897  1
saa7134_dvb            33269  0
videobuf_dvb           13867  1 saa7134_dvb
dvb_core               90587  1 videobuf_dvb
saa7134_alsa           18130  1
ir_kbd_i2c             13064  0
arc4                   12473  2
snd_hda_codec_realtek   255882  1
tda827x                17827  2
snd_hda_intel          24113  2
tda8290                22227  1
tuner                  26802  1
i915                  451053  3
snd_hda_codec          90901  2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep              13274  1 snd_hda_codec
snd_pcm                80042  3 saa7134_alsa,snd_hda_intel,snd_hda_codec
rtl8187                56206  0
snd_seq_midi           13132  0
saa7134               149236  2 saa7134_dvb,saa7134_alsa
drm_kms_helper         40971  1 i915
mac80211              257001  1 rtl8187
ir_lirc_codec          12770  0
lirc_dev               18720  1 ir_lirc_codec
ir_sony_decoder        12493  0
ir_jvc_decoder         12490  0
snd_rawmidi            25269  1 snd_seq_midi
ir_rc6_decoder         12490  0
ir_rc5_decoder         12490  0
ir_nec_decoder         12490  0
rc_core                25760  8 ir_kbd_i2c,saa7134,ir_lirc_codec,ir_sony_decoder,ir_jvc_decoder,ir_rc6_decoder,ir_rc5_decoder,ir_nec_decoder
snd_seq_midi_event     14475  1 snd_seq_midi
binfmt_misc            13213  1
snd_seq                51291  2 snd_seq_midi,snd_seq_midi_event
v4l2_common            16757  2 tuner,saa7134
ppdev                  12849  0
cfg80211              156212  2 rtl8187,mac80211
snd_timer              28659  2 snd_pcm,snd_seq
videodev               75143  3 tuner,saa7134,v4l2_common
drm                   184164  4 i915,drm_kms_helper
snd_seq_device         14110  3 snd_seq_midi,snd_rawmidi,snd_seq
parport_pc             32111  1
eeprom_93cx6           12653  1 rtl8187
videobuf_dma_sg        18747  3 saa7134_dvb,saa7134_alsa,saa7134
snd                    55295  16 saa7134_alsa,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
videobuf_core          25193  3 videobuf_dvb,saa7134,videobuf_dma_sg
tveeprom               17009  1 saa7134
soundcore              12600  1 snd
snd_page_alloc         14073  2 snd_hda_intel,snd_pcm
i2c_algo_bit           13184  1 i915
video                  18951  1 i915
lp                     13349  0
parport                36746  3 ppdev,parport_pc,lp
usbhid                 41704  0
hid                    77084  1 usbhid
r8169                  42534  0
direi che così a prima vista sembra che i moduli siano caricati
« Risposta #17 inserita:: Novembre 19, 2011, 10:22:23 pm »
Il modulo saa7134 viene caricato. Se vuoi passargli qualche opzione dovrai dapprima "rimuoverlo":
rmmod saa7134
quindi ricaricarlo con il comando:
modprobe -v saa7134 opzioni_varie
Per saperew quali parametri accetta puoi andare di:
modinfo saa7134
Considera che se dipende da un certo numeo di moduli (come in realtà dipedne -> depends:        videobuf-core,videobuf-dma-sg,i2c-core,ir-core,ir-common,videodev,tveeprom,v4l2-common) non puoi rimuoverlo con il comando sopra riportato e allora se devi passare qualche parametro/opzione l'unica cosa è utilizzare il file modprobe (sto andando a memoria in questo momento) presente in /etc (o nella omonima cartella /etc/modprobe.d).
Se hai difficoltà posta pure...
trimix
« Risposta #18 inserita:: Novembre 29, 2011, 12:11:26 am »
ciao ho ripreso in mano oggi la configurazione della scheda....purtroppo non mi fa rimuovere il driver:
robi@robi-desktop:~$ sudo rmmod saa7134
[sudo] password for robi:
ERROR: Module saa7134 is in use by saa7134_dvb,saa7134_alsa
robi@robi-desktop:~$ sudo rmmod saa7134_dvb
robi@robi-desktop:~$ sudo rmmod saa7134_alsa
ERROR: Module saa7134_alsa is in use
ERROR: Module saa7134 is in use by saa7134_alsa
se non ho capito male c'è saa7134_alsa che è in uso e non si fa smontare....c'è un modo di forzare il comando?
« Risposta #19 inserita:: Novembre 29, 2011, 03:50:17 pm »
Il modulo in questione ha diverse dipendenze, prova a fare così: rimuovilo utilizzando l'opzione -r di modprobe, in sostanza:
modprobe -r saa7134
viene rimosso? ...se non viene rimosso seguiremo un altro strada.
trimix
« Risposta #20 inserita:: Dicembre 01, 2011, 10:34:19 am »
ciao...ho delle pessime notizie da postare....la scheda che con molta pazienza mi avete aiutato a configurare non funziona come dovrebbe  Triste, per scupolo dopo i vari tentativi andati a vuoto l'ho testata su 2 pc con windows prima seven poi xp....e con entrambi dopo la sintonizzazione dei canali, perde il segnale e visto che questo succede non solo a casa mia anche nele case dove l'ho provata, seven e xp sono montati nei pc di due amici, posso escludere che il problema sia l'impianto.
Percui prima di farvi perdere altro tempo con qualcosa che non funziona fermo i lavori.....e mi metto in cerca di un altra scheda con le stesse caratteristiche dopo di che riprenderò a lavorarci e al limite scriverò di nuovo...
Per il momento vi ringrazio di cuore per il tempo e la competenza che molto gentilmente mi avete dedicato, scusandomi per avervi fatto perdere del tempo...
siete super...... grazie  Occhiolino
« Risposta #21 inserita:: Dicembre 01, 2011, 03:30:47 pm »
Strano comportamento questa scheda...  Che?!?
trimix
« Risposta #22 inserita:: Dicembre 02, 2011, 12:21:23 am »
in effetti...ci siamo rimasti male (io e gli amici che hanno collaborato)...e visto che non abbiamo spiegazioni riguardo al comportamento, l'abbiamo passata ad un elettronico....a volte le trovasse lui....anche se a volte è meglio non indagare...
ciao a presto :-)
trimix
« Risposta #23 inserita:: Dicembre 06, 2011, 10:52:04 am »
aggiorno il tread....siccome come scritto sopra la scheda tv sembra avere dei problemi...ho recuperato una avermedia a867....ho seguito la vostra guida:
http://www.linux-magazine.it/forum/index.php/topic,4473.0.html
e ho configurato per vedere la tv vlc media player, che dopo varie prove con altri player (tv time, me tv, ubuntuwintv, tv player) è risultato di gran lunga il migliore...
per la sua configurazione ho installato "w scan"  e poi ho seguito questa:
http://telperion.wordpress.com/2009/05/30/vlc-e-digitale-terrestre-dvb-t-su-linux/
nei menù di vlc ho selezionato la visione 16:9 e ora funziona tutto come dovrebbe.....
il sistema operativo che utilizzo è ubuntu 10.04....
ringrazio tutti e metto risolto con "variazione scheda"
il mio amico "elettronico" che sta testando la scheda al momento non ha trovato malfunzionamenti non escludo che possa più avanti riprenderla in mano e provare a configurarla di nuovo.....semmai ne riparleremo....
grazie   Occhiolino Ghigno
