Maggio 24, 2012, 05:56:11 pm *
Autore Discussione: Aiuto configurazione wpa_supplicant  (Letto 2399 volte)
andrea_alfa
« Risposta #15 inserita:: Agosto 04, 2011, 10:52:17 am »
dopo aver fatto tutto la tabella di routing è la seguente:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.1.254   0.0.0.0         UG    0      0        0 wlan0
non c'è assegnata nessuna destinazione... forse perchè è stato assegnato da me e non dal modem...
l'output di iwlist scan è il seguente:
wlan0     Scan completed :
          Cell 01 - Address: 00:A0:A2:45:DC:25
                    Channel:11
                    Frequency:2.462 GHz (Channel 11)
                    Quality=70/70  Signal level=-37 dBm
                    Encryption key:on
                    ESSID:"Digicom_11n"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s
                              18 Mb/s; 36 Mb/s; 54 Mb/s
                    Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s
                    Mode:Master
                    Extra:tsf=0000004b9474b138
                    Extra: Last beacon: 8ms ago
                    IE: Unknown: 000B44696769636F6D5F31316E
                    IE: Unknown: 010882848B961224486C
                    IE: Unknown: 03010B
                    IE: Unknown: 2A0104
                    IE: Unknown: 32040C183060
                    IE: Unknown: 2D1AEE1117FFFF0000010000000000000000000000000C0000000000
                    IE: Unknown: 3D160B070600000000000000000000000000000000000000
                    IE: Unknown: 3E0100
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (2) : TKIP CCMP
                        Authentication Suites (1) : PSK
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : TKIP
                    IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
                    IE: Unknown: 7F0101
                    IE: Unknown: DD900050F204104A00011010440001021041000100103B000103104700100000000000000001100000A0A245DC251021000C4D696368656C616E67656C6F1023000A576176652033303020431024000856312E3135532D441042000A4A3030393130323531371054000800060050F2040001101100164144534C322B2031316E20526F757465722857464129100800020004
                    IE: Unknown: DD07000C4304000000
                    IE: Unknown: 0706555320010B10
                    IE: Unknown: DD1E00904C33EE1117FFFF0000010000000000000000000000000C0000000000
                    IE: Unknown: DD1A00904C340B070600000000000000000000000000000000000000
ciao!
« Risposta #16 inserita:: Agosto 04, 2011, 06:52:35 pm »
... quindi, subito dopo aver fatto quanto detto prima, noi li diamo il resto con :
route add -net 192.168.1.0 netmask 255.255.255.0 wlan0
...e:
route add -net link-local netmask 255.255.0.0 wlan0
...e:
route add default gw 192.168.1.254 netmask 255.255.255.0 wlan0
...cosi la tabella del routing dovrebbe essere a posto, ma prima ricorda che sto considerando che hai già fatto quanto detto nel post anteriore, per ciò dico: "...subito dopo aver fatto quanto detto prima..."
D'altronde, leggendo in giro, potresti provare a configurare il file /etc/wpa_supplicant.conf cosi:
network={
   ssid="Digicom_11n"
   psk="CHIAVE WPA-PSK"
   key_mgmt=WPA-EAP WPA-PSK
   proto=RSN WPA
   pairwise=CCMP
Ricordavo di aver letto che questo comando:
sudo wpa_supplicant -iwlan0 -c/etc/wpa_supplicant.conf -d
...serve a far autenticare router e scheda.
...ti anticipo che l'output, ad un certo punto si ferma restituendo questo alle ultime due righe, qualcosa come:
RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
EAPOL: startWhen --> 0
...è normale. Significa che AP e scheda sono associati "Dovresti vedere attività"
info:  Se dai questo comando:
modinfo ath5k
...ottieni informazione dettagliata riguardo il modulo della tua scheda wireless
E se dai questo:
lshw -C network
...ottieni info riguardo i device network
Nota: bisognerebbe fare un post con tutta la procedura da 0 in modo tale da non commettere errori..., o no?  Occhi al cielo
a dopo
« Ultima modifica: Agosto 04, 2011, 06:54:25 pm da Argos » Registrato
« Risposta #17 inserita:: Agosto 05, 2011, 12:37:41 am »
...non ho seguito tutta la discussione, ma ogni tanto aiutatevi anche con i ping (ad esempio ad ogni possibile passaggio di aggiunta di una interfaccia).  Sorriso ...per vedere la raggiungibilità o meno.
Ma non ti conviene utilizzare il dhcp?
« Risposta #18 inserita:: Agosto 05, 2011, 08:48:17 am »
...in effetti se il DHCP va sarebbe meglio Sorriso
Apparte questo, ho trovato un'interfaccia grafica per la gestione del wpa_supplicant, come una curiosità:
http://en.wikipedia.org/wiki/Wpa_supplicant
a dopo
andrea_alfa
« Risposta #19 inserita:: Agosto 05, 2011, 02:24:54 pm »
ricapitolando...
ho provato a rifare tutta la procedura ma niente..l'indirizzo ip non compare nella tabella di routing
lo userei pure il DHCP se non fosse per quei errori che ti dicevo nel terzo post!
Io userei pure un gestore di rete ma sia network-manager che wicd mi danno problemi...in particolare wicd non rileva le reti wireless, network manager non gestisce l'ethernet ma pur un ignaro motivo non mi fa connettere alla rete wireless..
ho provato l'interfaccia grafica del wpa_supplicant (wpa_gui) ma mi dice che è impossibile ottenere lo status dal wpa_suppllicant e non mi permette di aggiungere reti manualmente...non va neanche la scansione delle reti..
inoltre il comando:
prosegue all'infinito...l'ho lasciato 10 minuti ma non finiva..va in loop..se serve posso postare parte dell'output!!
ciao!
« Risposta #20 inserita:: Agosto 06, 2011, 03:49:13 pm »
Quindi, a me sono due le cose che non mi convincono ancora, una il file /etc/network/interfaces , l'altra se il modulo ath5k stia funzionando a dovere.
Posta l'intero output di
lsmod
inoltre il comando:
...ma alla fine ti restituisce questo?:
Per ultimo wpa_supplicant, io non lo uso (ma è il mio caso) , e la connessione wireless va una bomba!!!, il mio modulo è questo: ar9170usb
...io proverei anche a lasciar stare il wpa_supplicant, cioè, provare a rinominarlo o spostarlo momentaniamente.
RIASSUNTO:
1_
lasciar libero il file /etc/network/interfaces , (salvati una copia da qualche parte nella home) modificarlo così:
auto lo
iface lo inet loopback
...basta, salva ed esci.
2_ Il file wpa_supplicant spostarlo nella home e lasciar solo la cartella /etc/wpa_supplicant con i suoi files: action_wpa.sh  functions.sh  ifupdown.sh intatti.
3_ ricaricare il modulo del device wireless con:
modprobe -r ath5k
poi:
modprobe -v ath5k
4_ riavviare con:
/etc/network/interfaces restart
5_ fare i controlli:
ifconfig
iwconfig
route
...navighi?  Occhi al cielo
P.S: Se il tuo device wireless supporta la tecnologia IEEE 802.11abg funziona con il modulo ath5k, se invece supporta la tecnologia IEEE 802.11n funziona col modulo ath9k
http://en.gentoo-wiki.com/wiki/Atheros_5xxx
http://linuxwireless.org/en/users/Drivers/ath5k
http://wireless.kernel.org/en/users/Drivers/ath9k
« Ultima modifica: Agosto 06, 2011, 04:18:59 pm da Argos » Registrato
« Risposta #21 inserita:: Agosto 07, 2011, 12:28:52 am »
...ma riguardo al dhcp, il demone:
dhcpcd
è attivato?  Che?!?  ...se non è attivato non può funzionare...  Occhi al cielo
