Maggio 24, 2012, 05:41:54 pm *
Autore Discussione: 3d sound usb non riconosciuta  (Letto 2766 volte)
pigreco26
« Risposta #15 inserita:: Luglio 11, 2011, 06:54:55 am »
0 [Intel          ]: HDA-Intel - HDA Intel
                      HDA Intel at 0xd7200000 irq 45
Il comando lo hai digitato con la scheda usb inserita??
...il punto è che non ricordo se la sintassi è giusta (domani se mi ricordo andrò a rivedermela), prova così:
modprobe -v snd_usb_audio vid=1130 pid=f211
La sintassi corretta dovrebbe essere:
sudo modprobe -v snd_usb_audio vid=0x1130 pid=0xf211
Nian prova e facci sapere Occhiolino
« Ultima modifica: Luglio 11, 2011, 06:58:32 am da pigreco26 » Registrato
Nian
« Risposta #16 inserita:: Luglio 11, 2011, 12:34:49 pm »
lspci;
00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
00:01.0 PCI bridge: Intel Corporation Mobile 4 Series Chipset PCI Express Graphics Port (rev 07)
00:1a.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 03)
00:1a.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 03)
00:1a.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 2 (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 03)
00:1d.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 93)
00:1f.0 ISA bridge: Intel Corporation ICH9M LPC Interface Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation ICH9M/M-E SATA AHCI Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 03)
00:1f.6 Signal processing controller: Intel Corporation 82801I (ICH9 Family) Thermal Subsystem (rev 03)
01:00.0 VGA compatible controller: nVidia Corporation G98 [GeForce 9200M GS] (rev a1)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 02)
03:00.0 Ethernet controller: Atheros Communications Inc. AR5001 Wireless Network Adapter (rev 01)
lspci -n:
00:00.0 0600: 8086:2a40 (rev 07)
00:01.0 0604: 8086:2a41 (rev 07)
00:1a.0 0c03: 8086:2937 (rev 03)
00:1a.1 0c03: 8086:2938 (rev 03)
00:1a.2 0c03: 8086:2939 (rev 03)
00:1a.7 0c03: 8086:293c (rev 03)
00:1b.0 0403: 8086:293e (rev 03)
00:1c.0 0604: 8086:2940 (rev 03)
00:1c.1 0604: 8086:2942 (rev 03)
00:1d.0 0c03: 8086:2934 (rev 03)
00:1d.1 0c03: 8086:2935 (rev 03)
00:1d.2 0c03: 8086:2936 (rev 03)
00:1d.7 0c03: 8086:293a (rev 03)
00:1e.0 0604: 8086:2448 (rev 93)
00:1f.0 0601: 8086:2919 (rev 03)
00:1f.2 0106: 8086:2929 (rev 03)
00:1f.3 0c05: 8086:2930 (rev 03)
00:1f.6 1180: 8086:2932 (rev 03)
01:00.0 0300: 10de:06e8 (rev a1)
02:00.0 0200: 10ec:8136 (rev 02)
03:00.0 0200: 168c:001c (rev 01)
lsmod | grep snd:
snd_usb_audio          91410  0
snd_usbmidi_lib        24388  1 snd_usb_audio
snd_hda_codec_hdmi     27535  1
snd_hda_codec_conexant    43782  1
snd_hda_intel          24140  2
snd_hda_codec          90901  3 snd_hda_codec_hdmi,snd_hda_codec_conexant,snd_hda_intel
snd_hwdep              13274  2 snd_usb_audio,snd_hda_codec
snd_pcm                80042  4 snd_usb_audio,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_seq_midi           13132  0
snd_rawmidi            25269  2 snd_usbmidi_lib,snd_seq_midi
snd_seq_midi_event     14475  1 snd_seq_midi
snd_seq                51291  2 snd_seq_midi,snd_seq_midi_event
snd_timer              28659  2 snd_pcm,snd_seq
snd_seq_device         14110  3 snd_seq_midi,snd_rawmidi,snd_seq
snd                    55295  16 snd_usb_audio,snd_usbmidi_lib,snd_hda_codec_hdmi,snd_hda_codec_conexant,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
soundcore              12600  1 snd
snd_page_alloc         14073  2 snd_hda_intel,snd_pcm
si
come output mi da
insmod /lib/modules/2.6.38-10-generic/kernel/sound/usb/snd-usb-audio.ko index=0 index=0 vid=0x1130 pid=0xf211
ma la scheda continua a non funzionare
EDIT: dopo aver riavviato il computer, ad un avvio più lento del solito è seguito un riconoscimento della scheda audio in questione che ora funziona XD
grazie dell'aiuto
« Ultima modifica: Luglio 11, 2011, 12:42:15 pm da Nian » Registrato
« Risposta #17 inserita:: Agosto 17, 2011, 11:20:03 pm »
Quindi ora la scheda viene correttamente riconosciuta? ...insomma, hai l'audio?  Sorriso
Nian
« Risposta #18 inserita:: Agosto 17, 2011, 11:28:48 pm »
ora viene riconosciuta regolarmente, anche se, a dirla tutta, dopo quel post la scheda ha funzionato solo fino al riavvio successivo, poi per altri motivi ho dovuto formattare tutto e installando direttamente ubuntu 11.04 da cd (prima avevo fatto l'aggiornamento da 10.10 a 11.04 tramite internet) non ho più avuto alcun tipo di problema di riconoscimento.
l'unico problema rimasto, a cui però ormai mi sono rassegnato visto che è più che altro un semplice inconveniente, è il fatto che non ho alcun tipo di controllo diretto sul volume generale. posso regolare il volume soltanto andando nelle preferenze audio a modificarlo per ogni singola applicazione (questa cosa mi succedeva anche con windows 7).
(se qualcuno ha qualche idea su come si potrebbe risolvere anche questa cosa sarei felicissimo di sentirlo, sennò come detto prima, mi ci sono rassegnato xD)
« Risposta #19 inserita:: Agosto 17, 2011, 11:36:34 pm »
...cioè con l'usuale mixer non riesci a regolare il volume? ...se provi da un terminale il comando:
alsamixer
riesci a regolare qualcosa? ...ma nel mixer la scheda viene vista? ...mica per caso ti vengono fornite possibili scelte tra più schede audio?
Nian
« Risposta #20 inserita:: Agosto 17, 2011, 11:48:55 pm »
nel mixer la scheda viene riconosciuta, e con alsamixer posso scegliere tra la scheda interna e la mia USB audio(non avendo comunque controllo sul volume). l'unico controllo che non funziona è quello generale.
frankcelli
« Risposta #21 inserita:: Agosto 20, 2011, 11:00:55 am »
Ciao, spero di non essere in ritardo dato il tempo trascorso...
Ubuntu 11.04 - Pen 3D SOUND inserita
Da riga di comando:
lsusb risponde
Bus 003 Device 011: ID 1130:f211 Tenx Technology, Inc. TP6911 Audio Headset
sudo modprobe -v snd_usb_audio vid=1130 pid=f211
carica il modulo snd_audio_usb che puoi controllare con  lsusb | grep snd
Poi devi chiamare Sistama>Preferenze>Audio, che apre la finestra "Preferenze dell'audio".
Da qui, tag Uscita, vedi i due dispositivi audio. Il secondo è
TP6911 Audio Headset Stereo analogico - Stereo
Spuntare il cerchietto per attivarlo.
Nel Tag Hardware puoi impostare il Profilo e fare il test degli altoparlanti.-
A me funziona.
« Risposta #22 inserita:: Agosto 20, 2011, 02:22:34 pm »
...non penso, sono passati solo meno di due giorni dall'ultimo post (escludendo il tuo).  Sorriso
