Maggio 24, 2012, 04:05:21 pm *
Autore Discussione: [Usb]USB 3.0 port Fresco FL1000G non funzionante ubuntu 10.04  (Letto 948 volte)
ps3love
« inserita:: Febbraio 06, 2011, 05:35:16 pm »
Ho la scheda madre asrock 880gmh/usb 3.0, ho il problema che con ubuntu 10.04 non mi funziona la porta usb 3.0 ne con pen drive 3.0 ne con pen drive 2.0 come posso fare ?
con il comando da terminale lspci:
00:00.0 Host bridge: Advanced Micro Devices [AMD] RS780 Host Bridge Alternate
00:01.0 PCI bridge: ASRock Incorporation Device 9602
00:07.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 3)
00:0a.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 5)
00:11.0 SATA controller: ATI Technologies Inc SB700/SB800 SATA Controller [IDE mode]
00:12.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller
00:12.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller
00:12.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller
00:13.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller
00:13.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller
00:13.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller
00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 3c)
00:14.1 IDE interface: ATI Technologies Inc SB700/SB800 IDE Controller
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA)
00:14.3 ISA bridge: ATI Technologies Inc SB700/SB800 LPC host controller
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge
00:14.5 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI2 Controller
00:18.0 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] HyperTransport Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Miscellaneous Control
00:18.4 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Link Control
01:05.0 VGA compatible controller: ATI Technologies Inc Device 9715
01:05.1 Audio device: ATI Technologies Inc RS880 Audio Device [Radeon HD 4200]
02:00.0 USB Controller: Device 1b73:1000 (rev 01)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 03)
con il comando da terminale lspci -v
Subsystem: ASRock Incorporation Device 9601
Flags: bus master, 66MHz, medium devsel, latency 0
Capabilities: [c4] HyperTransport: Slave or Primary Interface
Capabilities: [54] HyperTransport: UnitID Clumping
Capabilities: [40] HyperTransport: Retry Mode
Capabilities: [9c] HyperTransport: #1a
Capabilities: [f8] HyperTransport: #1c
Flags: bus master, 66MHz, medium devsel, latency 32
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: fe800000-fe9fffff
Prefetchable memory behind bridge: 00000000d0000000-00000000dfffffff
Capabilities: [44] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [b0] Subsystem: ASRock Incorporation Device 9602
Kernel modules: shpchp
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: fea00000-feafffff
Capabilities: [50] Power Management version 3
Capabilities: [58] Express Root Port (Slot+), MSI 00
Capabilities: [a0] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable+
Capabilities: [b0] Subsystem: ASRock Incorporation Device 9601
Capabilities: [b8] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [100] Vendor Specific Information <?>
Capabilities: [110] Virtual Channel <?>
Kernel driver in use: pcieport
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: feb00000-febfffff
Prefetchable memory behind bridge: 00000000fdf00000-00000000fdffffff
00:11.0 SATA controller: ATI Technologies Inc SB700/SB800 SATA Controller [IDE mode] (prog-if 01)
Subsystem: ASRock Incorporation Device 4390
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 22
I/O ports at c000 [size=8]
I/O ports at b000 [size=4]
I/O ports at a000 [size=8]
I/O ports at 9000 [size=4]
I/O ports at 8000 [size=16]
Memory at fe7ffc00 (32-bit, non-prefetchable) [size=1K]
Capabilities: [60] Power Management version 2
Capabilities: [70] SATA HBA <?>
Kernel driver in use: ahci
Kernel modules: ahci
00:12.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller (prog-if 10)
Subsystem: ASRock Incorporation Device 4397
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 16
Memory at fe7fe000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci_hcd
00:12.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller (prog-if 10)
Subsystem: ASRock Incorporation Device 4398
Memory at fe7fd000 (32-bit, non-prefetchable) [size=4K]
00:12.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller (prog-if 20)
Subsystem: ASRock Incorporation Device 4396
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 17
Memory at fe7ff800 (32-bit, non-prefetchable) [size=256]
Capabilities: [c0] Power Management version 2
Capabilities: [e4] Debug port: BAR=1 offset=00e0
Kernel driver in use: ehci_hcd
00:13.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller (prog-if 10)
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 18
Memory at fe7fc000 (32-bit, non-prefetchable) [size=4K]
00:13.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller (prog-if 10)
Memory at fe7fb000 (32-bit, non-prefetchable) [size=4K]
00:13.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller (prog-if 20)
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 19
Memory at fe7ff400 (32-bit, non-prefetchable) [size=256]
Subsystem: ASRock Incorporation Device 4385
Flags: 66MHz, medium devsel
Capabilities: [b0] HyperTransport: MSI Mapping Enable- Fixed+
Kernel modules: i2c-piix4
00:14.1 IDE interface: ATI Technologies Inc SB700/SB800 IDE Controller (prog-if 8a [Master SecP PriP])
Subsystem: ASRock Incorporation Device 439c
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 16
I/O ports at 01f0 [size=8]
I/O ports at 03f4 [size=1]
I/O ports at 0170 [size=8]
I/O ports at 0374 [size=1]
I/O ports at ff00 [size=16]
Capabilities: [70] Message Signalled Interrupts: Mask- 64bit- Queue=0/1 Enable-
Kernel driver in use: pata_atiixp
Kernel modules: pata_atiixp
Subsystem: ASRock Incorporation Device 1892
Flags: bus master, slow devsel, latency 32, IRQ 16
Memory at fe7f4000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
Subsystem: ASRock Incorporation Device 439d
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge (prog-if 01)
Bus: primary=00, secondary=04, subordinate=04, sec-latency=64
00:14.5 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI2 Controller (prog-if 10)
Subsystem: ASRock Incorporation Device 4399
Memory at fe7fa000 (32-bit, non-prefetchable) [size=4K]
Flags: fast devsel
Capabilities: [80] HyperTransport: Host or Secondary Interface
Flags: fast devsel
Flags: fast devsel
Flags: fast devsel
Capabilities: [f0] Secure device <?>
Flags: fast devsel
Subsystem: ASRock Incorporation Device 9715
Flags: bus master, fast devsel, latency 0, IRQ 28
Memory at d0000000 (32-bit, prefetchable) [size=256M]
I/O ports at d000 [size=256]
Memory at fe9f0000 (32-bit, non-prefetchable) [size=64K]
Memory at fe800000 (32-bit, non-prefetchable) [size=1M]
Capabilities: [a0] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable+
Kernel driver in use: fglrx_pci
Kernel modules: fglrx, radeon
Subsystem: ASRock Incorporation Device 970f
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at fe9e8000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [a0] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
02:00.0 USB Controller: Device 1b73:1000 (rev 01) (prog-if 30)
Subsystem: Device 1d5c:1000
Memory at feaf0000 (32-bit, non-prefetchable) [size=64K]
Capabilities: [68] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
Capabilities: [80] Express Endpoint, MSI 00
Kernel driver in use: xhci_hcd
Kernel modules: xhci
Subsystem: ASRock Incorporation Device 8168
Flags: bus master, fast devsel, latency 0, IRQ 27
I/O ports at e800 [size=256]
Memory at fdfff000 (64-bit, prefetchable) [size=4K]
Memory at fdff8000 (64-bit, prefetchable) [size=16K]
Expansion ROM at febe0000 [disabled] [size=128K]
Capabilities: [40] Power Management version 3
Capabilities: [50] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable+
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [ac] MSI-X: Enable- Mask- TabSize=4
Capabilities: [cc] Vital Product Data <?>
Capabilities: [100] Advanced Error Reporting <?>
Capabilities: [140] Virtual Channel <?>
Capabilities: [160] Device Serial Number 00-e0-4c-68-00-00-00-03
Kernel driver in use: r8169
Kernel modules: r8169
se può servire..dmesg | grep xhci
[    9.746351] xhci_hcd 0000:02:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[    9.746370] xhci_hcd 0000:02:00.0: setting latency timer to 64
[    9.746374] xhci_hcd 0000:02:00.0: xHCI Host Controller
[    9.746434] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 8
[    9.864520] xhci_hcd 0000:02:00.0: irq 19, io mem 0xfeaf0000
[    9.864734] xHCI xhci_add_endpoint called for root hub
[    9.864735] xHCI xhci_check_bandwidth called for root hub
[   45.268065] usb 8-2: new high speed USB device using xhci_hcd and address 0
[   65.268084] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
[   85.473043] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
[  105.676095] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
[  127.780151] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
[  150.780173] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
[  173.780145] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
[  195.804068] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
[  218.780181] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
[  238.908240] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
[  261.780159] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
[  289.096327] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
[  311.780195] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
[  333.964278] xhci_hcd 0000:02:00.0: Timeout while waiting for a slot
Il sito di Fresco Logic dichiara la sola compatibilità con windows, eppure ho letto che le prime dimostrazioni del supporto a usb 3 da parte del kernel linux hanno sfruttato un controller prodotto proprio da fresco logic.
ps3love
« Risposta #1 inserita:: Febbraio 06, 2011, 05:35:40 pm »
da natty non funziona
versione kernel Natty 32 bit live
Linux ubuntu 2.6.38-1-generic #28-Ubuntu SMP Fri Jan 28 15:17:31 UTC 2011 i686 athlon i386 GNU/Linux
00:00.0 Host bridge: Advanced Micro Devices [AMD] RS880 Host Bridge
00:0a.0 PCI bridge: Advanced Micro Devices [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 5)
00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor HyperTransport Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Miscellaneous Control
00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Link Control
01:05.0 VGA compatible controller: ATI Technologies Inc RS880 [Radeon HD 4250]
02:00.0 USB Controller: Fresco Logic FL1000G USB 3.0 Host Controller (rev 01)
00:01.0 PCI bridge: ASRock Incorporation Device 9602 (prog-if 00 [Normal decode])
00:07.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 3) (prog-if 00 [Normal decode])
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
00:0a.0 PCI bridge: Advanced Micro Devices [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 5) (prog-if 00 [Normal decode])
00:11.0 SATA controller: ATI Technologies Inc SB700/SB800 SATA Controller [IDE mode] (prog-if 01 [AHCI 1.0])
Subsystem: ASRock Incorporation Motherboard (one of many)
Capabilities: [70] SATA HBA v1.0
00:12.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller (prog-if 10 [OHCI])
00:12.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller (prog-if 10 [OHCI])
00:12.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller (prog-if 20 [EHCI])
00:13.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller (prog-if 10 [OHCI])
00:13.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller (prog-if 10 [OHCI])
00:13.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller (prog-if 20 [EHCI])
Kernel modules: sp5100_tco, i2c-piix4
Capabilities: [70] MSI: Enable- Count=1/2 Maskable- 64bit-
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge (prog-if 01 [Subtractive decode])
00:14.5 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI2 Controller (prog-if 10 [OHCI])
Flags: fast devsel
Flags: fast devsel
Flags: fast devsel
Flags: fast devsel
Kernel driver in use: k10temp
Kernel modules: k10temp
Flags: fast devsel
01:05.0 VGA compatible controller: ATI Technologies Inc RS880 [Radeon HD 4250] (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 18
Expansion ROM at <unassigned> [disabled]
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel driver in use: radeon
Kernel modules: radeon
02:00.0 USB Controller: Fresco Logic FL1000G USB 3.0 Host Controller (rev 01) (prog-if 30)
Flags: bus master, fast devsel, latency 0, IRQ 43
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel modules: xhci-hcd
Flags: bus master, fast devsel, latency 0, IRQ 42
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [ac] MSI-X: Enable- Count=4 Masked-
Capabilities: [160] Device Serial Number 03-00-00-00-68-4c-e0-00
da terminale con il comando dmesg | grep xhci
[   75.729603] xhci_hcd 0000:02:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[   75.729628] xhci_hcd 0000:02:00.0: setting latency timer to 64
[   75.729633] xhci_hcd 0000:02:00.0: xHCI Host Controller
[   75.729720] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 8
[   75.878101] xhci_hcd 0000:02:00.0: irq 19, io mem 0xfeaf0000
[   75.878120] xhci_hcd 0000:02:00.0: Failed to enable MSI-X
[   75.878175] xhci_hcd 0000:02:00.0: irq 43 for MSI/MSI-X
[   75.878346] xHCI xhci_add_endpoint called for root hub
[   75.878347] xHCI xhci_check_bandwidth called for root hub
Allego il dmesg.txt creato da ubuntu 11.04 natty
http://www.sendspace.com/file/v2bvq1
« Ultima modifica: Febbraio 06, 2011, 05:39:50 pm da ps3love » Registrato
« Risposta #2 inserita:: Febbraio 06, 2011, 10:20:34 pm »
Strano che si presentino problemi con USB 3.0 dato che il kernel GNU/Linux è stato il primo a funzionare con il nuovo standard (o pseudo tale), ben prima di Mac e Win.
Prova ad aprire un terminale e impartisci il comando:
tail -f /var/log/messages
a questo punto prova ad inserire un "qualcosa"  Ghigno di USB, quali sono le righe aggiuntive al comando precedente?
ps3love
« Risposta #3 inserita:: Febbraio 07, 2011, 12:57:06 am »
Senza penna inserita:
ps3@ps3-desktop:~$ tail -f /var/log/messages
Feb  7 00:51:24 ps3-desktop kernel: [   11.480947] [fglrx] IRQ 28 Enabled
Feb  7 00:51:24 ps3-desktop kernel: [   11.910064] [fglrx] Gart USWC size:1022 M.
Feb  7 00:51:24 ps3-desktop kernel: [   11.910067] [fglrx] Gart cacheable size:405 M.
Feb  7 00:51:24 ps3-desktop kernel: [   11.910070] [fglrx] Reserved FB block: Shared offset:0, size:1000000
Feb  7 00:51:24 ps3-desktop kernel: [   11.910072] [fglrx] Reserved FB block: Unshared offset:fffb000, size:5000
Feb  7 00:51:27 ps3-desktop kernel: [   14.303452] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Feb  7 00:51:28 ps3-desktop kernel: [   15.391078] hda-intel: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj.
Feb  7 00:51:55 ps3-desktop pulseaudio[1604]: ratelimit.c: 9 events suppressed
Feb  7 00:51:56 ps3-desktop kernel: [   43.848872] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Feb  7 00:51:59 ps3-desktop kernel: [   46.453692] padlock: VIA PadLock not detected.
Con la penna inserita:
ps3@ps3-desktop:~$ lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 046d:c05b Logitech, Inc.
Bus 002 Device 002: ID 058f:6362 Alcor Micro Corp. Hi-Speed 21-in-1 Flash Card Reader/Writer (Internal/External)
Bus 001 Device 004: ID 058f:6362 Alcor Micro Corp. Hi-Speed 21-in-1 Flash Card Reader/Writer (Internal/External)
Bus 001 Device 002: ID 0846:4260 NetGear, Inc. WG111(v3) 54 Mbps Wireless [RealTek RTL8187B]
ps3@ps3-desktop:~$
« Risposta #4 inserita:: Febbraio 08, 2011, 12:06:18 am »
Cioè non appare nessuna riga tra assenza di penna e subito dopo il collegamento della penna USB?!
Quindi è come se non collegassi nulla alla porta USB.  Broncio
Questo succede con qualsiasi porta USB utilizzi e/o con qualsiasi dongle USB in tuo possesso?  Broncio
Dal comndo USB vedo, però un po' di periferiche USB ...sono interne al computer oppure sono collegate esternamente?
ps3love
« Risposta #5 inserita:: Febbraio 08, 2011, 12:11:34 pm »
Esatto non appare nessuna riga di differenza con la penna e senza penna.
Si le porte usb 2.0 sono funzionanti, ma le porte usb 3.0 non funzionano ne con penne 2.0 ne con penne 3.0.
Le periferiche che vedi sono esterne 2.0 collegate su porta usb 2.0.
Mi sono informato e ho letto in giro che il supporto usb 3.0 dovrebbe essere pienamente supportato dal kernel 2.6.3.1, come puoi vedere anche con ubuntu natty 11.04 con kernel 2.6.3.8 non vanno le porte usb 3.0.
Irq esatto dell usb 3.0 è il 19 che non riesce ad agganciare.
« Ultima modifica: Febbraio 08, 2011, 12:13:06 pm da ps3love » Registrato
