Maggio 24, 2012, 03:38:41 pm *
Autore Discussione: 041e:4052 Creative Technology, Ltd Live! Cam Vista IM .. ma funziona con linux?  (Letto 1382 volte)
kokko
« inserita:: Gennaio 06, 2011, 09:03:54 pm »
salve raga
dopo anni di sbattimento non ci sono riuscito
solo su mandriva 2009 ha funzionato per un po...
prima c'erano i diver ov51x-jpeg , adesso sono integrati nei gspca_ov519 , il sensore e ov7670
root@slak:/home/kokko# lsusb
Bus 001 Device 004: ID 041e:4052 Creative Technology, Ltd Live! Cam Vista IM
lshw
Generic USB device
/0/100/1a/1/1/2
product: Creative Live! Cam Vista IM [41E:4052]
vendor: [41E]
bus info: usb@1:1.2
version: 1.00
capabilities:
   USB 1.1
configuration:
   driver: usbfs
   maxpower: 100mA
   speed: 12.0MB/s
root@slak:/home/kokko# lsmod | grep ov
gspca_ov519            32313  0
gspca_main             20146  1 gspca_ov519
root@slak:/home/kokko# modinfo gspca_ov519
filename:       /lib/modules/2.6.33.4-smp/kernel/drivers/media/video/gspca/gspca_ov519.ko
license:        GPL
description:    OV519 USB Camera Driver
author:         Jean-Francois Moine <http://moinejf.free.fr>
alias:          usb:v8020pEF04d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v1046p9967d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0E96pC001d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0B62p0059d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0813p0002d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v05A9pA518d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v05A9pA511d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v05A9p8519d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v05A9p4519d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v05A9p2800d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v05A9p0530d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v05A9p0519d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v05A9p0518d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v05A9p0511d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v054Cp0155d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v054Cp0154d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v045Ep028Cd*dc*dsc*dp*ic*isc*ip*
alias:          usb:v041Ep4068d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v041Ep4067d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v041Ep4064d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v041Ep4061d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v041Ep4060d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v041Ep405Fd*dc*dsc*dp*ic*isc*ip*
alias:          usb:v041Ep4052d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v041Ep4003d*dc*dsc*dp*ic*isc*ip*
depends:        gspca_main
vermagic:       2.6.33.4-smp SMP mod_unload 686
parm:           frame_rate:Frame rate (5, 10, 15, 20 or 30 fps) (int)
root@slak:/home/kokko# dmesg | grep ov519
ov519: Can't determine sensor slave IDs
ov519: OV519 Config failed
ov519: probe of 1-1.2:1.0 failed with error -16
usbcore: registered new interface driver ov519
ov519: registered
questo e quanto
cercando in giro con il modello del sensore  mi sembra che sia proprio indigesto ai sistemi linux in generale....
« Ultima modifica: Gennaio 06, 2011, 09:10:56 pm da kokko » Registrato
« Risposta #1 inserita:: Gennaio 06, 2011, 10:45:31 pm »
ciao kokko Sorriso
...si come hai detto che su mandriva ti he funzionata per un po  Occhi al cielo , prova ad inserirla di nuovo da mandriva e vedi cosa tirestituisce subito dopo il comando:
dmesg
Forze non ho capito bene  Occhi al cielo , la webcam funziona con un eseguibile sotto   /usr/sbin/   (come letto dall'output del tread anteriore: "Comando «/usr/sbin/gslapt» non trovato." ) e non con il modulo "patchato" , giusto? e questo eseguibile non si trova a fatto nel sottodirettorio, appunto;   /usr/sbin/ , servirà per caso anche qualche firmware sotto /lib/firmware?  Occhi al cielo , lancio la domanda cosi perché di solito è sempre il firmware.
Vedi nel sottodirettorio /lib/firmware di mandriva, dove hai detto che ti è funzionata per un po, nella lista dei firmware ti compare.
Hai già provato ad installare CHEESE?  Occhi al cielo
http://projects.gnome.org/cheese/
...lo puoi anche installare con il gestore dei pacchetti.
a dopo  Sorriso
« Ultima modifica: Gennaio 06, 2011, 11:05:46 pm da Argos » Registrato
kokko
« Risposta #2 inserita:: Gennaio 07, 2011, 01:33:10 pm »
ciao Argos
su mandriva 2009 avevo tentato di usare la webcam con virtualbox virtualizzando windows su un sistema mandriva
ed ero arrivato solo a farla funzionare per pochi secondi poi si piantava tutto
adesso mandriva non c'è l'ho più  sto usando slackware 13.1 kernel 2.6.33.4
mi sa che hai fatto un po di confusione , colpa mia non mi sono spiegato bene
la webcam sto tentando di usarla su slackware non funziona  non funziona neanche con altre distro compresa opensuse 11.4
l'errore che tu riporti e dell'altra discussione riguarda il gestore di pacchetti slapt-get e la sua interfaccia grafica gslapt usato su slackware
« Risposta #3 inserita:: Gennaio 07, 2011, 07:19:29 pm »
Nel 2.6.37 appena rilasciato, il (device) driver continua ad essere sviluppato:
http://lxr.linux.no/#linux+v2.6.37/drivers/media/video/gspca/ov519.c
e deriva, leggendo le prime righe, da un adattamento di:
http://www.rastageeks.org/ov51x-jpeg/index.php/Main_Page
che sembrerebbe, integrato oramai nel kernel sebbene vedo che c'è stato un aggiornamento a giugno 2010. Hai mai provatoa d utilizzare il device driver di rastageek? ...la versione attulamente scaricabile, la 1.5.9 è obsoleta (risale al 2008) e l'SVN, almeno in questo momento, sembra non raggiungibile.  Occhi al cielo
kokko
« Risposta #4 inserita:: Gennaio 09, 2011, 08:43:57 pm »
non so se è la stessa cosa ma  anche su una opensuse 11.4
Linux linux-pyj2 2.6.37-rc5-12-desktop #1 SMP PREEMPT 2010-12-09 16:04:57 +0100 x86_64 x86_64 x86_64 GNU/Linux
la web non e funzionante
stessi moduli stessi errori
............si gli ov51x-jpeg sono stati  integrati nei gspca  ma qualcosa va storto
la versione scaricabile non è piu  compatibile  sui kernel superiori al .30...
ho provato make ma non va da un sacco di errori..
« Risposta #5 inserita:: Gennaio 10, 2011, 12:14:33 am »
È questa la webcam? http://support.creative.com/Products/ProductDetails.aspx?catID=218&subCatID=219&prodID=14809&prodName=Live!%20Cam%20Notebook%20Pro%20(VF0250)&subCatName=WebCam&CatName=Web+Cameras
kokko
« Risposta #6 inserita:: Gennaio 10, 2011, 01:51:07 pm »
no la web e questa
http://it.creative.com/products/productarchive.asp?category=218&subcategory=219&product=15311&nav=
« Risposta #7 inserita:: Gennaio 10, 2011, 02:49:32 pm »
Ma anche con la OpenSUSE 11.4 il dmesg fornisce questo stesso output:
dmesg | grep ov519
ov519: registered
?? ...se è diverso riportalo....  Occhi al cielo
kokko
« Risposta #8 inserita:: Gennaio 13, 2011, 09:13:28 pm »
esattamente.......
« Risposta #9 inserita:: Gennaio 13, 2011, 10:39:06 pm »
Sembra che non riesca a "capire" quale sia il sensore che equipaggia la webcam.  Indeciso
Usi per caso un hub USB a cui colleaghi la webcam? ...se si, dai un'occhiata qui:
http://www.rastageeks.org/ov51x-jpeg/index.php/FAQ
in sostanza prova ad attaccare la webcam direttamente al PC (ammesso che questo sia il casol tuo).  Occhi al cielo
kokko
« Risposta #10 inserita:: Gennaio 24, 2011, 09:38:29 pm »
veramente l'ho attaccata dappertutto
sempre lo stesso risultato....
« Risposta #11 inserita:: Gennaio 26, 2011, 09:52:10 pm »
COn il modulo gspca e cam che fanno uso dell'ov519 si ha qualche problema da un po' di tempo a questa parte:
http://www.linuxquestions.org/questions/linux-hardware-18/fedora-12-vs-creative-labs-live-cam-notebook-807567/
e sembra che il problema sia legato al tipo di sensore presente nella cam stessa (come nel tuo caso dove non riesce a identificare il tipo di sensore). L'ultima versione del gspca è la:
http://moinejf.free.fr/gspca-2.12.4.tar.gz
ma nuovi sensori sono stati aggiunti in questi giorni, ad esempio:
http://git.linuxtv.org/media_tree.git?a=search&h=HEAD&st=commit&s=ov519
Potresti provare a scaricare la versione GIT o Mercurial di GSPCA e compilarla per verificare se la cam funziona o aspettare nuove versioni del kernel. Per caso conosci il modello del sensore integrato nella tua cam? ..a.d esempio se c'è scritto qualcosa sul manuale, sul sito del produttore etc...
Posta pure in caso di difficoltà/problemi...
