Maggio 24, 2012, 03:33:18 pm *
Autore Discussione: '/usr/sbin' is not included in the PATH environment variable.  (Letto 762 volte)
« inserita:: Dicembre 31, 2010, 11:42:31 pm »
Ho installato il modem USB SpeedTouch Manta su LMDE seguendo queste istruzioni:
http://www.linux-magazine.it/forum/index.php/topic,4260.0.html
Come potere vedere voi stessi,
linuxmintlmde@lmde / $ pppd
Command 'pppd' is available in '/usr/sbin/pppd'
The command could not be located because '/usr/sbin' is not included in the PATH environment variable.
This is most likely caused by the lack of administrative priviledges associated with your user account.
pppd: command not found
linuxmintlmde@lmde / $ /usr/sbin/pppd
Plugin /usr/lib/pppd/2.4.5/pppoatm.so loaded.
per far partire il modem non basta impartire il comando pppd, ma devo anche fornire il percorso in quanto, come scritto nell'output, "The command could not be located because '/usr/sbin' is not included in the PATH environment variable."
come includo la directory '/usr/sbin' nella PATH ?
« Risposta #1 inserita:: Gennaio 01, 2011, 12:29:16 pm »
Leggi
http://www.volalibero.it/aggiungere_variabili_ambiente.html
in particolare il paragrafo
PATH -- Modificare i percorsi
It's easy!  Occhiolino
