Maggio 24, 2012, 02:30:46 pm *
Autore Discussione: slackware 13 ---- k3b non completa la masterizzazione delle iso  (Letto 784 volte)
kokko
« inserita:: Ottobre 25, 2010, 01:22:17 pm »
salve raga
ho un nuovo problemino..
k3b 1.63.0 non mi finisce la masterizzazione delle iso
arriva  al 100%   ma non completa l'operazione
cioe il programma non si ferma..
qualche idea?
« Risposta #1 inserita:: Ottobre 25, 2010, 10:20:21 pm »
I file di log cosa riportano?
kokko
« Risposta #2 inserita:: Ottobre 27, 2010, 09:26:10 pm »
 chiedo scusa per l'ignoranza.....
dove vado a vedere?
intanto ho provato con win
funziona tutto e l'iso e buona...
EDIT:
ok ok  ci sono arrivato da solo...
UDF-fs: Partition marked readonly; forcing readonly mount
UDF-fs INFO UDF: Mounting volume '1_02', timestamp 2008/04/04 04:03 (1078)
cdrom: This disc doesn't have any tracks I recognize!
hdb: media error (blank): status=0x51 { DriveReady SeekComplete Error }
hdb: media error (blank): error=0x80 <3>{ LastFailedSense=0x08 }
ide: failed opcode was: unknown
ATAPI device hdb:
  Error: Blank check -- (Sense key=0x08)
  (reserved error code) -- (asc=0x00, ascq=0x00)
  The failed "Read 10" packet command was:
  "28 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 "
end_request: I/O error, dev hdb, sector 0
Buffer I/O error on device hdb, logical block 0
Buffer I/O error on device hdb, logical block 1
Buffer I/O error on device hdb, logical block 2
Buffer I/O error on device hdb, logical block 3
Buffer I/O error on device hdb, logical block 4
Buffer I/O error on device hdb, logical block 5
Buffer I/O error on device hdb, logical block 6
Buffer I/O error on device hdb, logical block 7
ATAPI device hdb:
  "28 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 "
ATAPI device hdb:
  "28 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 "
end_request: I/O error, dev hdb, sector 4
ATAPI device hdb:
ATAPI device hdb:
ATAPI device hdb:
  "28 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 "
warning: `growisofs' uses 32-bit capabilities (legacy support in use)
praticamente alla fine della masterizzazione
mentre che aspettavo   ok finale
poi ho chiuso k3b con "cancel"
« Ultima modifica: Ottobre 28, 2010, 09:23:19 pm da kokko » Registrato
« Risposta #3 inserita:: Novembre 16, 2010, 10:09:29 pm »
...non so se nel frattempo hai risolto (avevo perso di vista anche quest'altra discussione  Ghigno), ma con quale utente cerchi di fare la masterizzazione? ...ad esempio l'amministratore oppure "l'utente normale"?
kokko
« Risposta #4 inserita:: Novembre 23, 2010, 09:41:33 pm »
seeee  risolto......
magari!!!!!!
mi pare che ho provato da root e da utente
ma non fungeva
magari dimentico qualcosa......
« Risposta #5 inserita:: Novembre 28, 2010, 04:21:30 pm »
Hai provato a lanciare k3bsetup che trovi nel menù K?
