Maggio 24, 2012, 02:14:08 am *
Autore Discussione: [RISOLTO] - Scegliere il desktop environment all'avvio  (Letto 1124 volte)
Callejon
kallejon@hotmail.it
« inserita:: Settembre 03, 2010, 01:25:14 pm »
Ragazzi...
Secondo passo da affrontare: come posso scegliere all'avvio l'utilizzo di GNOME anzichè KDE? Sembra che esista un file attraverso il quale è possibile determinarne la selezione.
bash-4.1# cat /etc/rc.d/rc.4
#! /bin/sh
# rc.4      This file is executed by init(Fico when the system is being
#      initialized for run level 4 (XDM)
# Version:   @(#)/etc/rc.d/rc.4   2.00   02/17/93
# Author:   Fred N. van Kempen, <waltje@uwalt.nl.mugnet.org>
# At least 47% rewritten by:  Patrick J. Volkerding <volkerdi@slackware.com>
# Tell the viewers what's going to happen...
echo "Starting up X11 session manager..."
# Try to use GNOME's gdm session manager.  This comes first because if
# gdm is on the machine then the user probably installed it and wants
# to use it by default:
if [ -x /usr/bin/gdm ]; then
  exec /usr/bin/gdm -nodaemon
fi
# Someone thought that gdm looked prettier in /usr/sbin,
# so look there, too:
if [ -x /usr/sbin/gdm ]; then
  exec /usr/sbin/gdm -nodaemon
fi
# Not there?  OK, try to use KDE's kdm session manager:
#if [ -x /opt/kde/bin/kdm ]; then
#  exec /opt/kde/bin/kdm -nodaemon
#elif [ -x /usr/bin/kdm ]; then
#  exec /usr/bin/kdm -nodaemon
#fi
# If all you have is XDM, I guess it will have to do:
#if [ -x /usr/bin/xdm ]; then
#  exec /usr/bin/xdm -nodaemon
#elif [ -x /usr/X11R6/bin/xdm ]; then
#  exec /usr/X11R6/bin/xdm -nodaemon
#fi
# error
echo
echo "Hey, you don't have KDM, GDM, or XDM.  Can't use runlevel 4 without"
echo "one of those installed."
sleep 30
# All done.
bash-4.1#
Ho provato a mettere il cancelletto su KDE ma sembra che il SO ne ignori la forzatura. Premetto che ho installato il motore GNOME attraverso questo comando:
[quotelynx --source http://gnomeslackbuild.org/net-install | bash][/quote]
Cosa devo fare?
Ps. Inoltre ho notato che quando riavvio il pc attraverso il comando reboot, le impostazioni di background non vengono mantenute...
« Ultima modifica: Settembre 04, 2010, 01:20:11 am da Callejon_SuSE » Registrato
Pc in uso 1: ASUS EeePC R101
Utilizzo linux dal 15/10/2008
Membro Wikipedia dal 2009
robs
« Risposta #1 inserita:: Settembre 03, 2010, 01:56:46 pm »
per quanto ne so io gnome non è incluso....
cmq vai nel file /etc/inittab
e modifica questa linea
sostituendo 3 con 4
cosi si avvia l'interfaccia grafica,e il gestore dovrebbe essere kdm,ma ripeto,per quanto ne so non c' gnome,ma potrò dirlo con certezza tra non molto che sto aggiornando alla 13.1...ciao
ps:hai installato 13.1 o 13.0?
« Risposta #2 inserita:: Settembre 03, 2010, 03:40:24 pm »
Gnome è "fuori" da Slackware dal 2005/2006. Chi lo vuole dovrà affidarsi a terze parti che potete trovare in rete. ;-)
Callejon
kallejon@hotmail.it
« Risposta #3 inserita:: Settembre 03, 2010, 06:19:17 pm »
sostituendo 3 con 4
Ho installato la versione 13.1 e il desktop GNOME l'ho scaricato da rete. Ora provo a modificare il file /etc/inittab e vedo cosa succede...
Callejon
kallejon@hotmail.it
« Risposta #4 inserita:: Settembre 03, 2010, 06:30:12 pm »
Ok... ho modificato il file e adesso utilizzo GNOME... Un altro passo avanti...
robs
« Risposta #5 inserita:: Settembre 04, 2010, 12:04:15 am »
per completezza,riporta il link da dove l'hai scaricato non si sa mai che serve a qualcun altro,e metti risolto al post...
Callejon
kallejon@hotmail.it
« Risposta #6 inserita:: Settembre 04, 2010, 01:17:25 am »
I passi che ho seguito sono i seguenti:
Ho aperto il terminale e con diritti di amministratore ho digitato il seguente comando:
nano /etc/inittab
e mi si è presentato questo contenuto:
bash-4.1# cat /etc/inittab
# inittab   This file describes how the INIT process should set up
#      the system in a certain run-level.
# Version:   @(#)inittab      2.04   17/05/93   MvS
#                                       2.10    02/10/95        PV
#                                       3.00    02/06/1999      PV
#                                       4.00    04/10/2002      PV
# Author:   Miquel van Smoorenburg, <miquels@drinkel.nl.mugnet.org>
# Modified by:   Patrick J. Volkerding, <volkerdi@slackware.com>
# These are the default runlevels in Slackware:
#   0 = halt
#   1 = single user mode
#   2 = unused (but configured the same as runlevel 3)
#   3 = multiuser mode (default Slackware runlevel)
#   4 = X11 with KDM/GDM/XDM (session managers)
#   5 = unused (but configured the same as runlevel 3)
#   6 = reboot
# Default runlevel. (Do not set to 0 or 6)
# System initialization (runs when system boots).
si:S:sysinit:/etc/rc.d/rc.S
# Script to run when going single user (runlevel 1).
su:1S:wait:/etc/rc.d/rc.K
# Script to run when going multi user.
rc:2345:wait:/etc/rc.d/rc.M
# What to do at the "Three Finger Salute".
ca::ctrlaltdel:/sbin/shutdown -t5 -r now
# Runlevel 0 halts the system.
l0:0:wait:/etc/rc.d/rc.0
# Runlevel 6 reboots the system.
l6:6:wait:/etc/rc.d/rc.6
# What to do when power fails.
pf::powerfail:/sbin/genpowerfail start
# If power is back, cancel the running shutdown.
pg::powerokwait:/sbin/genpowerfail stop
# These are the standard console login getties in multiuser mode:
c1:1235:respawn:/sbin/agetty 38400 tty1 linux
c2:1235:respawn:/sbin/agetty 38400 tty2 linux
c3:1235:respawn:/sbin/agetty 38400 tty3 linux
c4:1235:respawn:/sbin/agetty 38400 tty4 linux
c5:1235:respawn:/sbin/agetty 38400 tty5 linux
c6:12345:respawn:/sbin/agetty 38400 tty6 linux
# Local serial lines:
#s1:12345:respawn:/sbin/agetty -L ttyS0 9600 vt100
#s2:12345:respawn:/sbin/agetty -L ttyS1 9600 vt100
# Dialup lines:
#d1:12345:respawn:/sbin/agetty -mt60 38400,19200,9600,2400,1200 ttyS0 vt100
#d2:12345:respawn:/sbin/agetty -mt60 38400,19200,9600,2400,1200 ttyS1 vt100
# Runlevel 4 used to be for an X window only system, until we discovered
# that it throws init into a loop that keeps your load avg at least 1 all
# the time. Thus, there is now one getty opened on tty6. Hopefully no one
# will notice. ;^)
# It might not be bad to have one text console anyway, in case something
# happens to X.
x1:4:respawn:/etc/rc.d/rc.4
# End of /etc/inittab
bash-4.1#
Ho modificato la stringa:
Originariamente il valore del runrevel era 3. L'ho modificata in 4 dimodochè al prossimo riavvio passasse direttamente al gestore grafico senza fermarsi al prompt.
Il secondo step è stato modificare il file /etc/rc.d/rc.4
Dove nel contenuto:
#! /bin/sh
fi
fi
#fi
#fi
# error
echo
sleep 30
# All done.
bash-4.1#
Ho inserito un cancelletto, alle voci che non appartenessero a GNOME. Infatti come si può notare, solo le prime stringhe sono rimaste libere:
fi]
Ho infine salvato tutto e riavviato, ed il gioco è fatto.  Occhiolino
Ho trovato una documentazione inerente a questa casistica al seguente indirizzo:
http://book.slackware.it/x-window-system-xdm.html
Callejon...
« Ultima modifica: Settembre 04, 2010, 01:21:16 am da Callejon_SuSE » Registrato
« Risposta #7 inserita:: Settembre 04, 2010, 10:35:46 pm »
Visto che ci sei  Felice ...riporta anche dove hai scaricato la versione di Gnome pacchettizzata considerando che è stata "eliminata" dal dvd di installazione.
Callejon
kallejon@hotmail.it
« Risposta #8 inserita:: Settembre 05, 2010, 03:10:08 pm »
Certamente...
il link dove ho scaricato e installato in automatico GNOME Slackbuild è al seguente indirizzo:
http://gnomeslackbuild.org/download/
Scorrendo la pagina si arriva alla sezione Quick and Easy Install
Si invita ad aprire il terminale e digitare:
Ci impiega circa dieci minuti (rapportato al mio pc che è un Centrino Duo da 1.6GHz)...
Callejon  Ghigno Ghigno Ghigno
« Ultima modifica: Settembre 05, 2010, 03:13:40 pm da Callejon_SuSE » Registrato
robs
« Risposta #9 inserita:: Settembre 06, 2010, 12:36:31 am »
...e aggiungo che sarebbe opportuno uscire dal server grafico,e passare al terzo runlevel,quindi prima di digitare il seguente comando
sarebbe opportuno dare
telinit 3
da utente root...come suggerito in una guida che ho letto di recente...ma ovviamente non trovo il link...
