Eseguo:
[code]utente1@TheThing:~$ lspci -v
00:00.0 Host bridge: Intel Corporation 82G33/G31/P35/P31 Express DRAM Controller (rev 02)
Subsystem: ASUSTeK Computer Inc. Device 8276
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
00:01.0 PCI bridge: Intel Corporation 82G33/G31/P35/P31 Express PCI Express Root Port (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: fea00000-feafffff
Prefetchable memory behind bridge: 00000000f0000000-00000000f7ffffff
Kernel driver in use: pcieport
Kernel modules: shpchp
00:1a.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 02) (prog-if 00 [UHCI])
Subsystem: ASUSTeK Computer Inc. Device 8277
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at c800 [size=32]
Kernel driver in use: uhci_hcd
Kernel modules: uhci-hcd
00:1a.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 21
I/O ports at c880 [size=32]
00:1a.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at cc00 [size=32]
00:1a.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 02) (prog-if 20 [EHCI])
Memory at fe9ffc00 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci_hcd
Kernel modules: ehci-hcd
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 02)
Subsystem: ASUSTeK Computer Inc. Device 829f
Flags: bus master, fast devsel, latency 0, IRQ 43
Memory at fe9f8000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: f8000000-f83fffff
Prefetchable memory behind bridge: 00000000fdf00000-00000000fdffffff
00:1c.4 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 5 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: feb00000-febfffff
Prefetchable memory behind bridge: 00000000f8400000-00000000f85fffff
00:1d.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
I/O ports at c080 [size=32]
00:1d.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 19
I/O ports at c400 [size=32]
00:1d.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 02) (prog-if 00 [UHCI])
I/O ports at c480 [size=32]
00:1d.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 02) (prog-if 20 [EHCI])
Memory at fe9ff800 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 92) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=32
00:1f.0 ISA bridge: Intel Corporation 82801IB (ICH9) LPC Interface Controller (rev 02)
00:1f.2 SATA controller: Intel Corporation 82801IB (ICH9) 4 port SATA AHCI Controller (rev 02) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 22
I/O ports at b000 [size=8]
I/O ports at ac00 [size=4]
I/O ports at a880 [size=8]
I/O ports at a800 [size=4]
I/O ports at a480 [size=32]
Memory at f8600000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 02)
Flags: medium devsel, IRQ 18
Memory at fe9ff400 (64-bit, non-prefetchable) [size=256]
I/O ports at 0400 [size=32]
Kernel modules: i2c-i801
00:1f.5 SATA controller: Intel Corporation Device 2927 (rev 02) (prog-if 01 [AHCI 1.0])
I/O ports at c000 [size=8]
I/O ports at bc00 [size=4]
I/O ports at b880 [size=8]
I/O ports at b800 [size=4]
I/O ports at b480 [size=32]
Memory at f8600800 (32-bit, non-prefetchable) [size=2K]
01:00.0 VGA compatible controller: ATI Technologies Inc RV380 0x3e50 [Radeon X600] (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. Device 001e
Flags: bus master, fast devsel, latency 0, IRQ 11
Memory at f0000000 (32-bit, prefetchable) [size=128M]
I/O ports at d000 [size=256]
Memory at feae0000 (32-bit, non-prefetchable) [size=64K]
Expansion ROM at feac0000 [disabled] [size=128K]
Kernel modules: radeon, radeonfb
01:00.1 Display controller: ATI Technologies Inc RV380 [Radeon X600] (Secondary)
Subsystem: ASUSTeK Computer Inc. Device 001f
Memory at feaf0000 (32-bit, non-prefetchable) [size=64K]
02:00.0 IDE interface: Marvell Technology Group Ltd. 88SE6121 SATA II Controller (rev b1) (prog-if 8f [Master SecP SecO PriP PriO])
Subsystem: ASUSTeK Computer Inc. Device 82a2
Flags: bus master, fast devsel, latency 0, IRQ 16
I/O ports at ec00 [size=8]
I/O ports at e880 [size=4]
I/O ports at e800 [size=8]
I/O ports at e480 [size=4]
I/O ports at e400 [size=16]
Memory at febffc00 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: pata_marvell
Kernel modules: ide-pci-generic
et pure
utente1@TheThing:~$ lspci -n
00:00.0 0600: 8086:29c0 (rev 02)
00:01.0 0604: 8086:29c1 (rev 02)
00:1a.0 0c03: 8086:2937 (rev 02)
00:1a.1 0c03: 8086:2938 (rev 02)
00:1a.2 0c03: 8086:2939 (rev 02)
00:1a.7 0c03: 8086:293c (rev 02)
00:1b.0 0403: 8086:293e (rev 02)
00:1c.0 0604: 8086:2940 (rev 02)
00:1c.4 0604: 8086:2948 (rev 02)
00:1d.0 0c03: 8086:2934 (rev 02)
00:1d.1 0c03: 8086:2935 (rev 02)
00:1d.2 0c03: 8086:2936 (rev 02)
00:1d.7 0c03: 8086:293a (rev 02)
00:1e.0 0604: 8086:244e (rev 92)
00:1f.0 0601: 8086:2918 (rev 02)
00:1f.2 0106: 8086:2923 (rev 02)
00:1f.3 0c05: 8086:2930 (rev 02)
00:1f.5 0106: 8086:2927 (rev 02)
01:00.0 0300: 1002:3e50
01:00.1 0380: 1002:3e70
02:00.0 0101: 11ab:6121 (rev b1)
Per quanto riguarda l'ormai annosa questione del menu.lst, ci siamo quasi...: quando Debian è appena installata menu.lst [a parte la 'sbrodolata' iniziale] ha le seguenti voci:
title Debian GNU/Linux, kernel 2.6.26-2-amd64
root (hd1,0)
kernel /vmlinuz-2.6.26-2-amd64 root=/dev/sda1 ro
initrd /initrd.img-2.6.26-2-amd64
title Debian GNU/Linux, kernel 2.6.26-2-amd64 (single-user mode)
root (hd1,0)
kernel /vmlinuz-2.6.26-2-amd64 root=/dev/sda1 ro single
Quando mi 'permetto' di installare bootchart diventa così [lo modifico a mano, dato che l'installatore di bootchart non lo fa, però funziona...]
root (hd1,0)
root (hd1,0)
title MyDebian_bootchart kernel 2.6.26-2-amd64 <--------------------------------------------------VOCE INSERITA ex novo
root (hd1,0)
kernel /vmlinuz-2.6.26-2-amd64 root=/dev/sda1 ro init=/sbin/bootchartd <----------- modifica per avviare bootchart
Quando infine installo un nuovo kernel tutto il blocchetto 'VOCE INSERITA ex novo' viene eliminato...
title Debian GNU/Linux, kernel 2.6.35-my0
root (hd1,0)
kernel /vmlinuz-2.6.35-my0 root=/dev/sda1 ro
title Debian GNU/Linux, kernel 2.6.35-my0 (single-user mode)
root (hd1,0)
kernel /vmlinuz-2.6.35-my0 root=/dev/sda1 ro single
root (hd1,0)
root (hd1,0)
[/code]
