Maggio 24, 2012, 12:30:49 am *
Autore Discussione: OpenSUSE 11.2: masterizzare da shell col comando wodim  (Letto 1435 volte)
« inserita:: Marzo 27, 2010, 03:03:42 pm »
In questa pagina
http://guide.debianizzati.org/index.php/Wodim:_masterizzare_da_shell
ho trovato le istruzioni per masterizzare da shell con Debian.
Siccome le istruzioni da shell sono spesso assai simili per tutti i linux, ho pensato che potevano funzionare anche per OpenSUSE 11.2, ma ho avuto qualche problema...
Ecco l'output.
linux-ojta:/mnt/Wy/Immagini/Mint # wodim dev=/dev/scd0 fs=14M speed=8 -dao -eject -overburn -v LinuxMint-8-LXDE-RC1.iso
TOC Type: 1 = CD-ROM
scsidev: '/dev/scd0'
devname: '/dev/scd0'
scsibus: -2 target: -2 lun: -2
Linux sg driver version: 3.5.27
Wodim version: 1.1.9
SCSI buffer size: 64512
Device type    : Removable CD-ROM
Version        : 5
Response Format: 2
Capabilities   :
Vendor_info    : 'HL-DT-ST'
Identification : 'DVD-RAM GH22NP20'
Revision       : '1.01'
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
Current: 0x000A (CD-RW)
Profile: 0x0012 (DVD-RAM)
Profile: 0x002B (DVD+R/DL)
Profile: 0x001B (DVD+R)
Profile: 0x001A (DVD+RW)
Profile: 0x0016 (DVD-R/DL layer jump recording)
Profile: 0x0015 (DVD-R/DL sequential recording)
Profile: 0x0014 (DVD-RW sequential recording)
Profile: 0x0013 (DVD-RW restricted overwrite)
Profile: 0x0011 (DVD-R sequential recording)
Profile: 0x0010 (DVD-ROM)
Profile: 0x000A (CD-RW) (current)
Profile: 0x0009 (CD-R)
Profile: 0x0008 (CD-ROM)
Profile: 0x0002 (Removable disk)
Using generic SCSI-3/mmc   CD-R/CD-RW driver (mmc_cdr).
Driver flags   : MMC-3 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
Drive buf size : 1114112 = 1088 KB
Beginning DMA speed test. Set CDR_NODMATEST environment variable if device
communication breaks or freezes immediately after that.
Errno: 5 (Input/output error), read buffer scsi sendcmd: no error
CDB:  3C 00 00 00 00 00 00 FC 00 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 04 00 00 00 00 0A 00 00 00 00 08 03 00 00
Sense Key: 0x4 Hardware Error, Segment 0
Sense Code: 0x08 Qual 0x03 (logical unit communication crc error (ultra-dma/32)) Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 0.001s timeout 200s
FIFO size      : 14680064 = 14336 KB
Track 01: data   668 MB
Total size:      768 MB (76:05.56) = 342417 sectors
Lout start:      768 MB (76:07/42) = 342417 sectors
Current Secsize: 2048
ATIP info from disk:
  Indicated writing power: 6
  Reference speed: 0
  Is not unrestricted
  Is erasable
  Disk sub type: Ultra High speed Rewritable media (2)
  ATIP start of lead in:  -11744 (97:25/31)
  ATIP start of lead out: 359848 (79:59/73)
  1T speed low: 16 1T speed high: 16
  2T speed low:  8 2T speed high: 24
  power mult factor: 1 4
  recommended erase/write power: 3
  A1 values: 66 18 B8
  A2 values: 38 80 00
  A3 values: 00 00 00
Disk type:    Phase change
Manuf. index: 40
Manufacturer: INFODISC Technology Co., Ltd.
Blocks total: 359848 Blocks current: 359848 Blocks remaining: 17431
Speed set to 2822 KB/s
Starting to write CD/DVD at speed  16.0 in real SAO mode for single session.
Last chance to quit, starting real write in    0 seconds. Operation starts.
Waiting for reader process to fill input buffer ... input buffer ready.
Performing OPC...
Sending CUE sheet...
Writing pregap for track 1 at -150
Starting new track at sector: 0
Track 01:    0 of  668 MB written.Errno: 5 (Input/output error), write_g1 scsi sendcmd: no error
CDB:  2A 00 00 00 00 9B 00 00 1F 00
cmd finished after 0.003s timeout 200s
write track data: error after 317440 bytes
wodim: A write error occured.
wodim: Please properly read the error message above.
Writing  time:   12.910s
Average write speed 354.2x.
Fixating...
Fixating time:    0.012s
wodim: fifo had 228 puts and 6 gets.
wodim: fifo was 0 times empty and 1 times full, min fill was 97%.
Dove sbaglio?
anche qui
http://forum.ubuntu-it.org/index.php/topic,249770.msg2880735.html#msg2880735
si dice che i comandi sono quelli...
« Ultima modifica: Marzo 27, 2010, 03:05:17 pm da Sargon6 » Registrato
« Risposta #1 inserita:: Marzo 27, 2010, 03:35:36 pm »
...forse per masterizzare una ISO hai inserito troppe opzioni. Nel sito che hai riportato ci sta, per le immagini;
wodim -v -eject dev=/dev/hdc speed=8 immagine.iso
Per avere ulteriore aiuto prova con il comando;
man wodim
(per uscire premi il tasto "Q").
Callejon
kallejon@hotmail.it
« Risposta #2 inserita:: Marzo 28, 2010, 11:06:41 am »
In questa pagina
Ecco l'output.
Version        : 5
Response Format: 2
Capabilities   :
Revision       : '1.01'
  Reference speed: 0
  Is not unrestricted
  Is erasable
  A1 values: 66 18 B8
  A2 values: 38 80 00
  A3 values: 00 00 00
Manuf. index: 40
Performing OPC...
Fixating...
Dove sbaglio?
anche qui
Provo a testarlo anche io e vedo se da lo stesso problema...
Pc in uso 1: ASUS EeePC R101
Utilizzo linux dal 15/10/2008
Membro Wikipedia dal 2009
Callejon
kallejon@hotmail.it
« Risposta #3 inserita:: Marzo 29, 2010, 09:01:49 am »
Ho provato a masterizzare un'immagine ISO con gli stessi comandi e sulla mia macchina non ha dato problemi. L'output che ricevo è il seguente:
ludovico@linux-cs7b:~/Scaricati/openSUSE-11.2-KDE4-LiveCD-i686-iso> wodim dev=/dev/scd0 fs=14M speed=8 -dao -eject -overburn -v openSUSE-11.2-KDE4-LiveCD-i686.iso
wodim: Operation not permitted. Warning: Cannot raise RLIMIT_MEMLOCK limits.scsidev: '/dev/scd0'
Version        : 5
Response Format: 2
Capabilities   :
Identification : 'DVDRAM GSA-T10N '
Revision       : 'PP02'
Current: 0x0011 (DVD-R sequential recording)
Profile: 0x0011 (DVD-R sequential recording) (current)
Using generic SCSI-3/mmc DVD-R(W) driver (mmc_mdvd).
Driver flags   : SWABAUDIO BURNFREE
Supported modes: PACKET SAO
Drive DMA Speed: 13246 kB/s 75x CD 9x DVD
Track 01: data   678 MB
Total size:      778 MB (77:08.48) = 347136 sectors
Lout start:      778 MB (77:10/36) = 347136 sectors
HINT: use dvd+rw-mediainfo from dvd+rw-tools for information extraction.
Blocks total: 2298496 Blocks current: 2298496 Blocks remaining: 1951360
Speed set to 11080 KB/s
Starting to write CD/DVD at speed   8.0 in real SAO mode for single session.
Performing OPC...
Track 01:  678 of  678 MB written (fifo 100%) [buf  67%]   3.6x.
Track 01: Total bytes read/written: 710934528/710934528 (347136 sectors).
Writing  time:  197.887s
Average write speed   2.7x.
Min drive buffer fill was 18%
Fixating...
Fixating time:   59.008s
wodim: fifo had 11198 puts and 11198 gets.
wodim: fifo was 0 times empty and 6125 times full, min fill was 96%.
Secondo me c'è qualcosa che cozza con il tuo hardware. Potresti postarne l'output?
« Risposta #4 inserita:: Marzo 29, 2010, 09:09:07 am »
...potrebbe mancargli anche qualche libreria...  Occhi al cielo
P.S.: Fate le prove sempre con i riscrivibili così non buttate via nulla, né soldi né plastica.  Felice
Callejon
kallejon@hotmail.it
« Risposta #5 inserita:: Marzo 29, 2010, 09:21:52 am »
Anche la tua osservazione è plausibile...
« Risposta #6 inserita:: Marzo 29, 2010, 11:03:15 am »
Ho provato a masterizzare un'immagine ISO con gli stessi comandi e sulla mia macchina non ha dato problemi. ...
Grazie per averlo provato, così ho la certezza che il comando va bene, e che il problema è o di hardware, o di dipendenze.
Dici questo?
ubuntu9v10@ubuntu9v10-desktop:~$ wodim --devices
wodim: Overview of accessible drives (2 found) :
 0  dev='/dev/scd0' rwrw-- : 'HL-DT-ST' 'DVD-RAM GH22NP20'
 1  dev='/dev/scd1' rwrw-- : 'MATSHITA' 'DVD-ROM SR-8587'
Se ti riferisci all'output del comando, l'ho inserito nel primo post.
http://www.linux-magazine.it/forum/index.php/topic,4160.msg19701.html#msg19701
Se ti riferisci all'output si qualche altro comando, fammi sapere a quale comando ti riferisci.
Callejon
kallejon@hotmail.it
« Risposta #7 inserita:: Marzo 29, 2010, 11:30:03 am »
Mi riferisco proprio a questa citazione che hai messo...
Guardando i vari forum sembra che il tuo modello HL-DT-ST' 'DVD-RAM GH22NP20 abbia qualche problemino a livello hardware verso wodim... L'utente michele.p chiedeva se le librerie ce l'hai tutte correttamente installate...
« Ultima modifica: Marzo 29, 2010, 11:32:22 am da Callejon_SuSE » Registrato
« Risposta #8 inserita:: Marzo 29, 2010, 11:47:36 am »
Non ho scorto nessun messaggio indicante una dipendenza insoddisfatta.
Se la verifica della presenza di tutte le librerie necessarie avviene tramite un comando specifico, ditemi quale comando devo dare, ed io ve ne fornirò l'output.
