slackware mi intriga,dovrei provarlo prima o poi
comunque,seguirò meglio quella discussione. intanto ho voluto provare a dare quel comando
~$ cd /usr/src/linux-source-2.6.32
$ sudo make localmodconfig
[sudo] password for mionome:
HOSTCC scripts/kconfig/conf.o
scripts/kconfig/conf.c: In function ‘conf_askvalue’:
scripts/kconfig/conf.c:105: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
scripts/kconfig/conf.c: In function ‘conf_choice’:
scripts/kconfig/conf.c:307: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
HOSTCC scripts/kconfig/kxgettext.o
HOSTCC scripts/kconfig/zconf.tab.o
HOSTLD scripts/kconfig/conf
using config: '.config'
nvidia config not found!!
* Restart config...
* Touchscreens
Touchscreens (INPUT_TOUCHSCREEN) [Y/n/?] y
ADS7846/TSC2046 and ADS7843 based touchscreens (TOUCHSCREEN_ADS7846) [N/m/y/?] n
AD7877 based touchscreens (TOUCHSCREEN_AD7877) [N/m/y/?] n
AD7879 based touchscreens: AD7879-1 I2C Interface (TOUCHSCREEN_AD7879_I2C) [N/m/y/?] n
AD7879 based touchscreens: AD7879 SPI Interface (TOUCHSCREEN_AD7879_SPI) [N/m/y/?] (NEW) n
Touchscreen support for Dialog Semiconductor DA9034 (TOUCHSCREEN_DA9034) [N/m/y/?] n
EETI touchscreen panel support (TOUCHSCREEN_EETI) [N/m/y/?] n
Fujitsu serial touchscreen (TOUCHSCREEN_FUJITSU) [N/m/y/?] n
Gunze AHL-51S touchscreen (TOUCHSCREEN_GUNZE) [N/m/y/?] n
Elo serial touchscreens (TOUCHSCREEN_ELO) [N/m/y/?] n
Wacom W8001 penabled serial touchscreen (TOUCHSCREEN_WACOM_W8001) [N/m/y/?] n
MELFAS MCS-5000 touchscreen (TOUCHSCREEN_MCS5000) [N/m/y/?] n
MicroTouch serial touchscreens (TOUCHSCREEN_MTOUCH) [N/m/y/?] n
iNexio serial touchscreens (TOUCHSCREEN_INEXIO) [N/m/y/?] n
ICS MicroClock MK712 touchscreen (TOUCHSCREEN_MK712) [N/m/y/?] n
HTC Shift X9500 touchscreen (TOUCHSCREEN_HTCPEN) [N/m/y/?] n
Penmount serial touchscreen (TOUCHSCREEN_PENMOUNT) [N/m/y/?] n
Touchright serial touchscreen (TOUCHSCREEN_TOUCHRIGHT) [N/m/y/?] n
Touchwin serial touchscreen (TOUCHSCREEN_TOUCHWIN) [N/m/y/?] n
Support for WM97xx AC97 touchscreen controllers (TOUCHSCREEN_WM97XX) [N/m/?] n
USB Touchscreen Driver (TOUCHSCREEN_USB_COMPOSITE) [N/m/y/?] n
Sahara TouchIT-213 touchscreen (TOUCHSCREEN_TOUCHIT213) [N/m/y/?] n
TSC2007 based touchscreens (TOUCHSCREEN_TSC2007) [N/m/y/?] n
* GPIO Support
GPIO Support (GPIOLIB) [Y/n/?] y
/sys/class/gpio/... (sysfs interface) (GPIO_SYSFS) [Y/n/?] y
* Memory mapped GPIO expanders:
* I2C GPIO expanders:
MAX7319, MAX7320-7327 I2C Port Expanders (GPIO_MAX732X) [N/m/y/?] n
PCA953x, PCA955x, TCA64xx, and MAX7310 I/O ports (GPIO_PCA953X) [N/m/y/?] n
PCF857x, PCA{85,96}7x, and MAX732[89] I2C GPIO expanders (GPIO_PCF857X) [N/m/y/?] n
TWL4030, TWL5030, and TPS659x0 GPIOs (GPIO_TWL4030) [N/m/y/?] n
* PCI GPIO expanders:
BT8XX GPIO abuser (GPIO_BT8XX) [N/m/y/?] (NEW) ?
CONFIG_GPIO_BT8XX:
The BT8xx frame grabber chip has 24 GPIO pins than can be abused
as a cheap PCI GPIO card.
This chip can be found on Miro, Hauppauge and STB TV-cards.
The card needs to be physically altered for using it as a
GPIO card. For more information on how to build a GPIO card
from a BT8xx TV card, see the documentation file at
Documentation/bt8xxgpio.txt
If unsure, say N.
Symbol: GPIO_BT8XX [=n]
Prompt: BT8XX GPIO abuser
Defined at drivers/gpio/Kconfig:177
Depends on: GPIOLIB [=y] && PCI [=y] && VIDEO_BT848 [=n]=n [=n]
-> Device Drivers
-> GPIO Support (GPIOLIB [=y])
Intel Moorestown Platform Langwell GPIO support (GPIO_LANGWELL) [N/y/?] n
* SPI GPIO expanders:
Maxim MAX7301 GPIO expander (GPIO_MAX7301) [N/m/y/?] n
Microchip MCP23S08 I/O expander (GPIO_MCP23S08) [N/m/y/?] n
Freescale MC33880 high-side/low-side switch (GPIO_MC33880) [N/m/y/?] n
* AC97 GPIO expanders:
# configuration written to .config
LoL! pian piano... seguirò il metodo tradizionale di compilazione comunque per ora,con make menuconfig magari
grazie ancora!
