...spuntando mi restituisce questo:
A causa delle loro dipendenze, devono essere rimossi anche i seguenti pacchetti:
- nvidia-current-kernel-desktop586-latest-180.51-1.20090817.1mdv2009.1.i586
Altri 0B di spazio disco saranno utilizzati.
- nvidia173-kernel-desktop586-latest-173.14.18-1.20090817.2mdv2009.1.i586
- nvidia96xx-kernel-desktop586-latest-96.43.11-1.20090817.5mdv2009.1.i586
E se spunto questi (in neretto):
x11-driver-video-nvidia-current - NVIDIA proprietary X.org driver and libraries for GeForce 6 and later cards
NVIDIA proprietary X.org graphics driver, related libraries and configuration tools for GeForce 6 and later cards, including the associated Quadro cards.
NOTE: You should use XFdrake to configure your NVIDIA card. The correct packages will be automatically installed and configured.
If you do not want to use XFdrake, see README.manual-setup.
This NVIDIA driver should be used with GeForce 6 and later cards, including the associated Quadro cards. For older cards, the packages x11-driver-video-nvidia96xx and x11-driver-video-nvidia71xx should be used instead.
x11-driver-video-nvidia173 - NVIDIA proprietary X.org driver and libraries for GeForce FX based cards
NVIDIA proprietary X.org graphics driver, related libraries and configuration tools for GeForce FX based cards, including the associated Quadro cards.
This NVIDIA driver should be used with GeForce FX based cards, including the associated Quadro cards. For older cards, the packages x11-driver-video-nvidia96xx and x11-driver-video-nvidia71xx should be used instead.
x11-driver-video-nvidia96xx - NVIDIA proprietary X.org driver and libraries for most GF2/3/4 class cards
NVIDIA proprietary X.org graphics driver, related libraries and configuration tools for most NVIDIA GeForce2/3/4 class video cards.
This NVIDIA driver should be used with GeForce 3, GeForce4 and GeForce 2 MX cards. For older cards, the package x11-driver-video-nvidia71xx should be used. For newer cards, the package x11-driver-video-nvidia97xx should be used.
Non mi restituisce niente. Mi toglie solo quello esposto nella pria citazione
grazie e a dopo
