Maggio 23, 2012, 09:52:28 pm *
Autore Discussione: [RISOLTO] - [AIUTO] - Come si cambia la schermata di login  (Letto 605 volte)
Callejon
kallejon@hotmail.it
« inserita:: Agosto 10, 2009, 05:47:47 pm »
dopo qualche mese sono riuscito a capire come si cambia il login sulla distro OpenSuSE.
Per chi è interessare seguire quanto segue:
Aprire il terminale
e digitare il comando:
cd /etc/sysconfig/
all'interno di essa con i privilegi di root digitare:
nano displaymanager
e comparirà quanto segue (ovviamente qualcosa può variare dipendente dal sistema):
## Path:   Desktop/Display manager
## Description:   settings to generate a proper displaymanager config
## Type:   string(kdm,kdm3,kdm4,xdm,gdm,wdm,console)
## Default:   ""
# Here you can set the default Display manager (kdm/xdm/gdm/wdm/console).
# all changes in this file require a restart of the displaymanager
DISPLAYMANAGER="gdm"
## Type:   yesno
## Default:   no
# Allow remote access (XDMCP) to your display manager (xdm/kdm/gdm). Please note
# that a modified kdm or xdm configuration, e.g. by KDE control center
# will not be changed. For gdm, values will be updated after change.
# XDMCP service should run only on trusted networks and you have to disable
# firewall for interfaces, where you want to provide this service.
DISPLAYMANAGER_REMOTE_ACCESS="no"
## Type:   yesno
## Default:   no
# Allow remote access of the user root to your display manager. Note
# that root can never login if DISPLAYMANAGER_SHUTDOWN is "auto" and
# System/Security/Permissions/PERMISSION_SECURITY is "paranoid"
DISPLAYMANAGER_ROOT_LOGIN_REMOTE="no"
## Type:   yesno
## Default:   yes
# Let the displaymanager start a local Xserver.
# Set to "no" for remote-access only.
# Set to "no" on architectures without any Xserver (e.g. s390/s390x).
DISPLAYMANAGER_STARTS_XSERVER="yes"
## Type:        yesno
## Default:     no
# TCP port 6000 of Xserver. When set to "no" (default) Xserver is
# started with "-nolisten tcp". Only set this to "yes" if you really
# need to. Remote X service should run only on trusted networks and
# you have to disable firewall for interfaces, where you want to
# provide this service. Use ssh X11 port forwarding whenever possible.
DISPLAYMANAGER_XSERVER_TCP_PORT_6000_OPEN="no"
## Type:    string
## Default:
# Define the user whom should get logged in without request. If string
# is empty, display standard login dialog.
DISPLAYMANAGER_AUTOLOGIN=""
## Type:        yesno
## Default:     no
# Allow all users to login without password, but ask for the user, if
# DISPLAYMANAGER_AUTOLOGIN is empty.
DISPLAYMANAGER_PASSWORD_LESS_LOGIN="no"
## Type:        yesno
## Default:     no
# Display a combobox for Active Directory domains.
DISPLAYMANAGER_AD_INTEGRATION="no"
## Type:    list(root,all,none,auto)
## Default: auto
# Determine who will be able to shutdown or reboot the system in kdm
# and gdm. Valid values are: "root" (only root can shutdown), "all"
# (everybody can shutdown), "none" (nobody can shutdown from
# displaymanager), "auto" (follow
# System/Security/Permissions/PERMISSION_SECURITY to decide: "easy
# local" is equal to "all", everything else is equal to "root"). Note
# that remote user can never shutdown in GDM.
DISPLAYMANAGER_SHUTDOWN="auto"
## Type:        string
## Default:     ""
# Mode to configure on output devices by default
# (RANDR 1.2 compatible drivers only).
# If set to "auto", DISPLAYMANAGER_RANDR_MODE_auto is used on laptops, and
# the empty string on workstations.
# The output is not explicitly enabled (read: disabled) if set to an empty
# string.
# If the variable contains a fully configured modeline (see default of
# DISPLAYMANAGER_RANDR_MODE_auto), the mode is defined and set.
# If the variable contains a mode name only, the mode has to be defined
# already.
# If a monitor is attached during Xstartup, or when invoking "xrandr --auto"
# during runtime, the output is correctly configured and a mode is
# automatically selected if none has been used so far.
# Variables are checked according to their extension for
#    VGA DVI_I DVI_D DVI_A Composite S_Video Component LFP Proprietary
DISPLAYMANAGER_RANDR_MODE_VGA=""
#DISPLAYMANAGER_RANDR_MODE_DVI_I=""
#DISPLAYMANAGER_RANDR_MODE_DVI_D=""
#DISPLAYMANAGER_RANDR_MODE_DVI_A=""
#DISPLAYMANAGER_RANDR_MODE_Compsite=""
#DISPLAYMANAGER_RANDR_MODE_S_Video=""
#DISPLAYMANAGER_RANDR_MODE_Component=""
#DISPLAYMANAGER_RANDR_MODE_LFP=""
#DISPLAYMANAGER_RANDR_MODE_Proprietary=""
## Type:        string
## Default:     "1024x768_60 64.11 1024 1080 1184 1344 768 769 772 795 -HSync +Vsync"
# Mode to use for laptops for DISPLAYMANAGER_RANDR_MODE_* on laptops only,
# when the according variable is set to "auto".
DISPLAYMANAGER_RANDR_MODE_auto="1024x768_60 64.11 1024 1080 1184 1344 768 769 772 795 -HSync +Vsync"
## Type:        string(Xorg)
## Default:     "Xorg"
DISPLAYMANAGER_XSERVER="Xorg"
## Config:      kdm3
## Type:    string
## Default:
# space separated list of users for which icons should be shown in KDM
# if empty, then take system defaults
KDM_USERS=""
## Type:    string
## Default:
# Special greeting words in kdm
KDM_GREETSTRING=""
## Type:        string
## Default:
# Defines extra Server Arguments given to the kdm display manager when
# starting a local display. Useful to override e.g. the -dpi setting.
DISPLAYMANAGER_KDM_LOCALARGS=""
## Type:        string
## Default:     SUSE
# Define the theme to be used by kdm. If empty, the traditional login
# window is used (which lacks some features)
DISPLAYMANAGER_KDM_THEME="SUSE"
All'interno del file spostiamoci sulla variabile:
e cambiamo a nostre preferenze quello che desideriamo:
Infatti come riporta la stringa:
cambiamo da gdm a kdm o wdm etc...
IMPORTANTE: E' necessario scaricare con YaST tutti i pacchetti. Quindi se desideriamo visualizzare kdm digiteremo su cerca kdm.
 Ghigno
« Ultima modifica: Aprile 12, 2010, 04:26:44 pm da Callejon_SuSE » Registrato
Pc in uso 1: ASUS EeePC R101
Utilizzo linux dal 15/10/2008
Membro Wikipedia dal 2009
« Risposta #1 inserita:: Agosto 10, 2009, 09:08:35 pm »
...ci sono alcune discussioni nella community Italiana dedicata a OpenSUSE;
KDE -> http://www.suseitalia.org/modules/newbb/viewtopic.php?topic_id=21103&forum=1&post_id=125675#forumpost125675
Gnome -> http://www.suseitalia.org/modules/newbb/viewtopic.php?viewmode=flat&topic_id=21457&forum=7
...ti riferivi a questo?
P.S.: Ma poi per i codec mp4 - http://www.linux-magazine.it/index.php/topic,3625.msg15160.html#msg15160 - hai risolto?
Callejon
kallejon@hotmail.it
« Risposta #2 inserita:: Agosto 11, 2009, 10:05:32 am »
Ciao, per quanto riguarda il codec MP4 ho risolto (e mi scuso per non averlo comunicato qui), invece per il discorso della schermata di login andrò a vedere adesso e poi ti dirò com'è andata...
Callejon
kallejon@hotmail.it
« Risposta #3 inserita:: Agosto 11, 2009, 11:43:21 am »
A quanto pare non funziona...
