Maggio 23, 2012, 09:44:39 pm *
Autore Discussione: modem connexant  (Letto 1181 volte)
alien
« inserita:: Agosto 02, 2009, 10:44:32 pm »
Salve!
ho un acer con ubuntu 9.04, mi ha rilevato tutto ubuntu tranne il modem 56k interno.
Funziona solo con windows, e anche con windows non so che modello è.
dice solo V90.
qualcuno di voi dirà posta l'output di lspci, cosa strana non risulta nell'outup.
ecco l'houtput:
00:00.0 Host bridge: Intel Corporation Mobile 915GM/PM/GMS/910GML Express Processor to DRAM Controller (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 1 (rev 04)
00:1c.1 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 2 (rev 04)
00:1c.2 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 3 (rev 04)
00:1d.0 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 04)
00:1d.1 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 04)
00:1d.2 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3 (rev 04)
00:1d.3 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4 (rev 04)
00:1d.7 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 04)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev d4)
00:1f.0 ISA bridge: Intel Corporation 82801FBM (ICH6M) LPC Interface Bridge (rev 04)
00:1f.1 IDE interface: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) IDE Controller (rev 04)
00:1f.3 SMBus: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev 04)
06:01.0 CardBus bridge: Texas Instruments PCI1510 PC card Cardbus Controller
06:04.0 Network controller: Intel Corporation PRO/Wireless 2200BG [Calexico2] Network Connection (rev 05)
06:08.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
c'è il sito linuxant ma ci sono tre tipi di modem HSF, HCF e un altro che non ricordo.
Li ho provati tutti per la mia versione di kernel ma non funziona.
cioè non esce nessun errore all'avvio e in lspci non c'è nulla.
dove dovrebbe trovarsi questo modem ? in /dev/modem ?
non c'è nulla
« Risposta #1 inserita:: Agosto 02, 2009, 11:33:50 pm »
...potresti riportare di preciso il modello del tuo Acer? ...vedi mai che c'è già qualche guida pronta....  Ghigno  ...comunque a parte qualche raro caso, i modem interni sono alquanto complicati da far funzionare....
« Risposta #2 inserita:: Agosto 03, 2009, 12:03:23 am »
Salve!
Moltissimi modem interni costruiti dopo la seconda metà del 1998 non funzionano con Linux visto che sono software modem che funzionano solo sotto Windows e sono spesso chiamati "winmodem".
http://www.pluto.it/files/ildp/HOWTO/Modem-HOWTO/Modem-HOWTO-2.html#soft_modem
alien
« Risposta #3 inserita:: Agosto 03, 2009, 12:15:58 am »
Il modello è acer1644wlmi da parte della serie 1640.
Ma ho cantrollato già io su google e non c'e nulla.
Si sa solo la marca del resto non sò nulla di sto modem, neppure sul sito acer dice molto.
Hanno fatto i driver ma lo ignorano il modem.
In realtà non è che mi serve dato che navigo con il cell come modem, però se c'e...
« Risposta #4 inserita:: Agosto 03, 2009, 11:38:07 am »
...il tuo 1644 è qui;
http://romeoxbm.altervista.org/acer_debian/
ma, se non sbaglio, non dice nulla sul modem. Prova a leggere la guida. Ad ogni modo riporta l'output del comando;
lspci -n
alien
« Risposta #5 inserita:: Agosto 03, 2009, 02:19:34 pm »
ecco :
salvatore@acer:~$ lspci -n
00:00.0 0600: 8086:2590 (rev 03)
00:02.0 0300: 8086:2592 (rev 03)
00:02.1 0380: 8086:2792 (rev 03)
00:1b.0 0403: 8086:2668 (rev 04)
00:1c.0 0604: 8086:2660 (rev 04)
00:1c.1 0604: 8086:2662 (rev 04)
00:1c.2 0604: 8086:2664 (rev 04)
00:1d.0 0c03: 8086:2658 (rev 04)
00:1d.1 0c03: 8086:2659 (rev 04)
00:1d.2 0c03: 8086:265a (rev 04)
00:1d.3 0c03: 8086:265b (rev 04)
00:1d.7 0c03: 8086:265c (rev 04)
00:1e.0 0604: 8086:2448 (rev d4)
00:1f.0 0601: 8086:2641 (rev 04)
00:1f.1 0101: 8086:266f (rev 04)
00:1f.3 0c05: 8086:266a (rev 04)
06:01.0 0607: 104c:ac56
06:04.0 0280: 8086:4220 (rev 05)
06:08.0 0200: 10ec:8139 (rev 10)
salvatore@acer:~$
per installare c'èra scritto che dovevo installare "alsa-driver-conexant"
bello davvero, dopo aver riavviato non funzionava alsa, ad ogni riavvio uscivano un sacco di righe NON erano di warning o di errore ma alla fine non mi funzionava alsa.
mi sono stancato e ho reinstallato di nuovo ubuntu dato che aveva bisogno.
Ci rinuncio mi sta bene anche senza modem, grazie lo stesso.
alien
« Risposta #6 inserita:: Agosto 03, 2009, 02:30:13 pm »
l'indirizzo http://romeoxbm.altervista.org/acer_debian/ che mi hai dato è del 2006.
Funziona tutto come funzionava in windows anche se sembra + veloce.
la grafica funziona anche con il 3D
l'audio al max volume in windows si bloccava il pc, con linux invece no.
quello che voglio dire è che qualsiasi distribuzione provo funziona tutto come con windows senza installare nulla.
« Risposta #7 inserita:: Agosto 03, 2009, 02:52:33 pm »
...comunque del modem incorporato non c'è proprio traccia nell'output dei comandi.  Che?!?   ...in questo modo è un po difficile orientarsi sul come procedere....  Occhi al cielo
alien
« Risposta #8 inserita:: Agosto 03, 2009, 04:14:02 pm »
ha risposto direttamente il supporto tecnico di conexant, non ci speravo:
adesso traduco e provo!
Hi,
I don't see a modem in the dump you have provided but it is most likely attached to this device (HDA bus):
    Subsystem: Acer Incorporated [ALI] Device 008f
    Flags: bus master, fast devsel, latency 0, IRQ 16
    Memory at d000c000 (64-bit, non-prefetchable) [size=16K]
    Capabilities: [50] Power Management version 2
    Capabilities: [60] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
    Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
    Capabilities: [100] Virtual Channel <?>
    Capabilities: [130] Root Complex Link <?>
    Kernel driver in use: HDA Intel
    Kernel modules: snd-hda-intel
While the module is loaded for this device, no sound card shows up so I expect a problem with the snd-hda-intel module which is affecting the possible HDA modem.
You should install alsa-driver-linuxant available at:
http://www.linuxant.com/alsa-driver/
reboot and then run the installer again. HDA modems are HSF and if yours is based on a Conexant chipset, it will be supported by the HSF driver.
Regards,
« Risposta #9 inserita:: Agosto 03, 2009, 09:50:22 pm »
Se ben ricordo c'è una utility che permette di fare una "scansione" del modem interno e dire di che tipo si tratta ...chi ricorda come si chiama questa utility? ...sto provando a cercarla su freashmeat, me non mi riesce....
Al di là di questo, tu hai provato a installare quei driver che ti indicano però non è andta proprio bene, giusto?
alien
« Risposta #10 inserita:: Agosto 03, 2009, 11:17:47 pm »
Si esatto si chiama scanModen già provato.
Però dopo partito lo scipt diceva che c'era un errore all'intero dello script con parentesi tonde.
Invece ho installato come dicono il modulo x alsa e non uscivano errori ma il suono dell'intero pc non funzionava.
« Risposta #11 inserita:: Agosto 04, 2009, 05:51:25 pm »
...l'output;
modprobe -l | grep snd-hda
cosa ti restituisce?
alien
« Risposta #12 inserita:: Agosto 04, 2009, 06:32:39 pm »
kernel/sound/pci/hda/snd-hda-intel.ko
« Risposta #13 inserita:: Agosto 04, 2009, 08:35:41 pm »
Ma la volta scorsa hai provato ad installare il pacchetto adatto alla versione del tuo kernel da qui;
http://www.linuxant.com/alsa-driver/downloads-ubuntu-x86.php
se è un 32bit altrimenti da qui se 64bit;
http://www.linuxant.com/alsa-driver/downloads-ubuntu-x86_64.php
Sembrerebbe l'unico driver (modulo) possibile installabile ...ammesso che il modem interno sia un Conexcant. La cosa strana è che non si sa nulla su quel modem.  Che?!?  ..sul manuale allegato al portatile e/o in rete non si trova proprio nulla?
