robs
« Risposta #7 inserita:: Maggio 15, 2009, 01:34:18 pm » |
ciao...innanzi tutto scusami se a volte impiego un po di tempo per rispondere...ma sono fuori sede,e non sempre riesco ad avere una connessione...cmq il file kismet.conf è:
# Kismet config file # Most of the "static" configs have been moved to here -- the command line # config was getting way too crowded and cryptic. We want functionality, # not continually reading --help!
# Version of Kismet config version=2007.09.R1
# Name of server (Purely for organizational purposes) servername=Kismet
# User to setid to (should be your normal user) suiduser=root
# Do we try to put networkmanager to sleep? If you use NM, this is probably # what you want to do, so that it will leave the interfaces alone while # Kismet is using them. This requires DBus support! networkmanagersleep=true
# Sources are defined as: # source=sourcetype,interface,name[,initialchannel] # Source types and required drivers are listed in the README under the # CAPTURE SOURCES section. # The initial channel is optional, if hopping is not enabled it can be used # to set the channel the interface listens on. # YOU MUST CHANGE THIS TO BE THE SOURCE YOU WANT TO USE source=none,none,addme
# Comma-separated list of sources to enable. This is only needed if you defined # multiple sources and only want to enable some of them. By default, all defined # sources are enabled. # For example: # enablesources=prismsource,ciscosource
# Automatically destroy VAPs on multi-vap interfaces (like madwifi-ng). # Madwifi-ng doesn't work in rfmon when non-rfmon VAPs are present, however # this is a fairly invasive change to the system so it CAN be disabled. Expect # things not to work in most cases if you do disable it, however. vapdestroy=true
# Do we channelhop? channelhop=true
# How many channels per second do we hop? (1-10) channelvelocity=5
# By setting the dwell time for channel hopping we override the channelvelocity # setting above and dwell on each channel for the given number of seconds. #channeldwell=10
# Do we split channels between cards on the same spectrum? This means if # multiple 802.11b capture sources are defined, they will be offset to cover # the most possible spectrum at a given time. This also controls splitting # fine-tuned sourcechannels lines which cover multiple interfaces (see below) channelsplit=true
# Basic channel hopping control: # These define the channels the cards hop through for various frequency ranges # supported by Kismet. More finegrain control is available via the # "sourcechannels" configuration option. # # Don't change the IEEE80211<x> identifiers or channel hopping won't work.
# Users outside the US might want to use this list: defaultchannels=IEEE80211b:1,7,13,2,8,3,14,9,4,10,5,11,6,12,14 #defaultchannels=IEEE80211b:1,6,11,2,7,3,8,4,9,5,10
# 802.11g uses the same channels as 802.11b... defaultchannels=IEEE80211g:1,7,13,2,8,3,14,9,4,10,5,11,6,12,14
# 802.11a channels are non-overlapping so sequential is fine. You may want to # adjust the list depending on the channels your card actually supports. defaultchannels=IEEE80211a:36,40,44,48,52,56,60,64,100,104,108,112,116,120,124,128,132,136,140,149,153,157,161,184,188,192,196,200,204,208,212,216 #defaultchannels=IEEE80211a:36,40,44,48,52,56,60,64
# Combo cards like Atheros use both 'a' and 'b/g' channels. Of course, you # can also explicitly override a given source. You can use the script # extras/listchan.pl to extract all the channels your card supports. defaultchannels=IEEE80211ab:1,7,13,2,8,3,14,9,4,10,5,11,6,12,14,36,40,44,48,52,60,56,64,100,104,108,112,116,120,124,128,132,136,140,149,153,157,161,184,188,192,196,299,294,298,212,216
# Fine-tuning channel hopping control: # The sourcechannels option can be used to set the channel hopping for # specific interfaces, and to control what interfaces share a list of # channels for split hopping. This can also be used to easily lock # one card on a single channel while hopping with other cards. # Any card without a sourcechannel definition will use the standard hopping # list. # sourcechannels=sourcename[,sourcename]:ch1,ch2,ch3,...chN
# ie, for us channels on the source 'prism2source' (same as normal channel # hopping behavior): # sourcechannels=prism2source:1,6,11,2,7,3,8,4,9,5,10
# Given two capture sources, "prism2a" and "prism2b", we want prism2a to stay # on channel 6 and prism2b to hop normally. By not setting a sourcechannels # line for prism2b, it will use the standard hopping. # sourcechannels=prism2a:6
# To assign the same custom hop channel to multiple sources, or to split the # same custom hop channel over two sources (if splitchannels is true), list # them all on the same sourcechannels line: # sourcechannels=prism2a,prism2b,prism2c:1,6,11
# Port to serve GUI data tcpport=2501 # People allowed to connect, comma seperated IP addresses or network/mask # blocks. Netmasks can be expressed as dotted quad (/255.255.255.0) or as # numbers (/24) allowedhosts=127.0.0.1 # Address to bind to. Should be an address already configured already on # this host, reverts to INADDR_ANY if specified incorrectly. bindaddress=127.0.0.1 # Maximum number of concurrent GUI's maxclients=5
# Do we have a GPS? gps=true # Host:port that GPSD is running on. This can be localhost OR remote! gpshost=localhost:2947 # Do we lock the mode? This overrides coordinates of lock "0", which will # generate some bad information until you get a GPS lock, but it will # fix problems with GPS units with broken NMEA that report lock 0 gpsmodelock=false
# Packet filtering options: # filter_tracker - Packets filtered from the tracker are not processed or # recorded in any way. # filter_dump - Packets filtered at the dump level are tracked, displayed, # and written to the csv/xml/network/etc files, but not # recorded in the packet dump # filter_export - Controls what packets influence the exported CSV, network, # xml, gps, etc files. # All filtering options take arguments containing the type of address and # addresses to be filtered. Valid address types are 'ANY', 'BSSID', # 'SOURCE', and 'DEST'. Filtering can be inverted by the use of '!' before # the address. For example, # filter_tracker=ANY(!00:00:DE:AD:BE:EF) # has the same effect as the previous mac_filter config file option. # filter_tracker=... # filter_dump=... # filter_export=...
# Alerts to be reported and the throttling rates. # alert=name,throttle/unit,burst/unit # The throttle/unit describes the number of alerts of this type that are # sent per time unit. Valid time units are second, minute, hour, and day. # Burst rates control the number of packets sent at a time # For example: # alert=FOO,10/min,5/sec # Would allow 5 alerts per second, and 10 alerts total per minute. # A throttle rate of 0 disables throttling of the alert. # See the README for a list of alert types. alert=NETSTUMBLER,10/min,1/sec alert=WELLENREITER,10/min,1/sec alert=LUCENTTEST,10/min,1/sec alert=DEAUTHFLOOD,10/min,2/sec alert=BCASTDISCON,10/min,2/sec alert=CHANCHANGE,5/min,1/sec alert=AIRJACKSSID,5/min,1/sec alert=PROBENOJOIN,10/min,1/sec alert=DISASSOCTRAFFIC,10/min,1/sec alert=NULLPROBERESP,10/min,1/sec alert=BSSTIMESTAMP,10/min,1/sec alert=MSFBCOMSSID,10/min,1/sec alert=LONGSSID,10/min,1/sec alert=MSFDLINKRATE,10/min,1/sec alert=MSFNETGEARBEACON,10/min,1/sec alert=DISCONCODEINVALID,10/min,1/sec alert=DEAUTHCODEINVALID,10/min,1/sec
# Known WEP keys to decrypt, bssid,hexkey. This is only for networks where # the keys are already known, and it may impact throughput on slower hardware. # Multiple wepkey lines may be used for multiple BSSIDs. # wepkey=00:DE:AD:C0:DE:00,FEEDFACEDEADBEEF01020304050607080900
# Is transmission of the keys to the client allowed? This may be a security # risk for some. If you disable this, you will not be able to query keys from # a client. allowkeytransmit=true
# How often (in seconds) do we write all our data files (0 to disable) writeinterval=300
# How old (and inactive) does a network need to be before we expire it? # This is really only good for limited ram environments where keeping a # total log of all networks is problematic. This is in seconds, and should # be set to a large value like 12 or 24 hours. This is intended for use # on stationary systems like an IDS # logexpiry=86400
# Do we limit the number of networks we log? This is for low-ram situations # when tracking everything could lead to the system falling down. This # should be combined with a sane logexpiry value to flush out very old # inactive networks. This is mainly for stationary systems like an IDS. # limitnets=10000
# Do we track IVs? this can help identify some attacks, but takes a LOT # of memory to do so on a busy network. If you have the RAM, by all # means turn it on. trackivs=false
# Do we use sound? # Not to be confused with GUI sound parameter, this controls wether or not the # server itself will play sound. Primarily for headless or automated systems. sound=false # Path to sound player soundplay=/usr/bin/play # Optional parameters to pass to the player # soundopts=--volume=.3 # New network found sound_new=${prefix}/share/kismet/wav/new_network.wav # Wepped new network # sound_new_wep=${prefix}/com/kismet/wav/new_wep_network.wav # Network traffic sound sound_traffic=${prefix}/share/kismet/wav/traffic.wav # Network junk traffic found sound_junktraffic=${prefix}/share/kismet/wav/junk_traffic.wav # GPS lock aquired sound # sound_gpslock=${prefix}/share/kismet/wav/foo.wav # GPS lock lost sound # sound_gpslost=${prefix}/share/kismet/wav/bar.wav # Alert sound sound_alert=${prefix}/share/kismet/wav/alert.wav
# Does the server have speech? (Again, not to be confused with the GUI's speech) speech=false # Server's path to Festival festival=/usr/bin/festival # Are we using festival lite? If so, set the above "festival" path to also # point to the "flite" binary flite=false # Are we using Darwin speech? darwinsay=false # What voice do we use? (Currently only valid on Darwin) speech_voice=default # How do we speak? Valid options: # speech Normal speech # nato NATO spellings (alpha, bravo, charlie) # spell Spell the letters out (aye, bee, sea) speech_type=nato # speech_encrypted and speech_unencrypted - Speech templates # Similar to the logtemplate option, this lets you customize the speech output. # speech_encrypted is used for an encrypted network spoken string # speech_unencrypted is used for an unencrypted network spoken string # # %b is replaced by the BSSID (MAC) of the network # %s is replaced by the SSID (name) of the network # %c is replaced by the CHANNEL of the network # %r is replaced by the MAX RATE of the network speech_encrypted=New network detected, s.s.i.d. %s, channel %c, network encrypted. speech_unencrypted=New network detected, s.s.i.d. %s, channel %c, network open.
# Where do we get our manufacturer fingerprints from? Assumed to be in the # default config directory if an absolute path is not given. ap_manuf=ap_manuf client_manuf=client_manuf
# Use metric measurements in the output? metric=true
# Do we write waypoints for gpsdrive to load? Note: This is NOT related to # recent versions of GPSDrive's native support of Kismet. waypoints=false # GPSDrive waypoint file. This WILL be truncated. waypointdata=%h/.gpsdrive/way_kismet.txt # Do we want ESSID or BSSID as the waypoint name ? waypoint_essid=false
# How many alerts do we backlog for new clients? Only change this if you have # a -very- low memory system and need those extra bytes, or if you have a high # memory system and a huge number of alert conditions. alertbacklog=50
# File types to log, comma seperated # dump - raw packet dump # network - plaintext detected networks # csv - plaintext detected networks in CSV format # xml - XML formatted network and cisco log # weak - weak packets (in airsnort format) # cisco - cisco equipment CDP broadcasts # gps - gps coordinates logtypes=dump,network,csv,xml,weak,cisco,gps
# Do we track probe responses and merge probe networks into their owners? # This isn't always desireable, depending on the type of monitoring you're # trying to do. trackprobenets=true
# Do we log "noise" packets that we can't decipher? I tend to not, since # they don't have anything interesting at all in them. noiselog=false
# Do we log corrupt packets? Corrupt packets have enough header information # to see what they are, but someting is wrong with them that prevents us from # completely dissecting them. Logging these is usually not a bad idea. corruptlog=true
# Do we log beacon packets or do we filter them out of the dumpfile beaconlog=true
# Do we log PHY layer packets or do we filter them out of the dumpfile phylog=true
# Do we mangle packets if we can decrypt them or if they're fuzzy-detected mangledatalog=true
# Do we do "fuzzy" crypt detection? (byte-based detection instead of 802.11 # frame headers) # valid option: Comma seperated list of card types to perform fuzzy detection # on, or 'all' fuzzycrypt=wtapfile,wlanng,wlanng_legacy,wlanng_avs,hostap,wlanng_wext,ipw2200,ipw2915
# Do we do forgiving fuzzy packet decoding? This lets us handle borked drivers # which don't indicate they're including FCS, and then do. fuzzydecode=wtapfile,radiotap_bsd_a,radiotap_bsd_g,radiotap_bsd_bg,radiotap_bsd_b,pcapfile
# Do we use network-classifier fuzzy-crypt detection? This means we expect # packets that are associated with an encrypted network to be encrypted too, # and we process them by the same fuzzy compare. # This essentially replaces the fuzzycrypt per-source option. netfuzzycrypt=true
# What type of dump do we generate? # valid option: "wiretap" dumptype=wiretap # Do we limit the size of dump logs? Sometimes ethereal can't handle big ones. # 0 = No limit # Anything else = Max number of packets to log to a single file before closing # and opening a new one. dumplimit=0
# Do we write data packets to a FIFO for an external data-IDS (such as Snort)? # See the docs before enabling this. #fifo=/tmp/kismet_dump
# Default log title logdefault=Kismet
# logtemplate - Filename logging template. # This is, at first glance, really nasty and ugly, but you'll hardly ever # have to touch it so don't complain too much. # # %n is replaced by the logging instance name # %d is replaced by the current date as Mon-DD-YYYY # %D is replaced by the current date as YYYYMMDD # %t is replaced by the starting log time # %i is replaced by the increment log in the case of multiple logs # %l is replaced by the log type (dump, status, crypt, etc) # %h is replaced by the home directory # ie, "netlogs/%n-%d-%i.dump" called with a logging name of "Pok" could expand # to something like "netlogs/Pok-Dec-20-01-1.dump" for the first instance and # "netlogs/Pok-Dec-20-01-2.%l" for the second logfile generated. # %h/netlots/%n-%d-%i.dump could expand to # /home/foo/netlogs/Pok-Dec-20-01-2.dump # # Other possibilities: Sorting by directory # logtemplate=%l/%n-%d-%i # Would expand to, for example, # dump/Pok-Dec-20-01-1 # crypt/Pok-Dec-20-01-1 # and so on. The "dump", "crypt", etc, dirs must exist before kismet is run # in this case. logtemplate=%n-%d-%i.%l
# Where do we store the pid file of the server? piddir=/var/run/
# Where state info, etc, is stored. You shouldnt ever need to change this. # This is a directory. configdir=%h/.kismet/
# cloaked SSID file. You shouldn't ever need to change this. ssidmap=ssid_map
# Group map file. You shouldn't ever need to change this. groupmap=group_map
# IP range map file. You shouldn't ever need to change this. ipmap=ip_map
grazie per l'aiuto e la disponibilita....
