Salve a tutti ho scaricato e compilato monkeyaudioplugins
dato il classico ./configure ok almake errore seguente
make all-recursive
make[1]: Entering directory `/home/daniele/k3bmonkeyaudioplugin-3.1'
Making all in po
make[2]: Entering directory `/home/daniele/k3bmonkeyaudioplugin-3.1/po'
rm -f de.gmo; : -o de.gmo ./de.po
test ! -f de.gmo || touch de.gmo
make[2]: Leaving directory `/home/daniele/k3bmonkeyaudioplugin-3.1/po'
Making all in src
make[2]: Entering directory `/home/daniele/k3bmonkeyaudioplugin-3.1/src'
Making all in libmonkeyaudio
make[3]: Entering directory `/home/daniele/k3bmonkeyaudioplugin-3.1/src/libmonkeyaudio'
Making all in Assembly
make[4]: Entering directory `/home/daniele/k3bmonkeyaudioplugin-3.1/src/libmonkeyaudio/Assembly'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/daniele/k3bmonkeyaudioplugin-3.1/src/libmonkeyaudio/Assembly'
make[4]: Entering directory `/home/daniele/k3bmonkeyaudioplugin-3.1/src/libmonkeyaudio'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/home/daniele/k3bmonkeyaudioplugin-3.1/src/libmonkeyaudio'
make[3]: Leaving directory `/home/daniele/k3bmonkeyaudioplugin-3.1/src/libmonkeyaudio'
make[3]: Entering directory `/home/daniele/k3bmonkeyaudioplugin-3.1/src'
if /bin/bash ../libtool --silent --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I. -I.. -I./libmonkeyaudio -I/usr/include/kde -I/usr/share/qt3/include -I. -DBUILD_CROSS_PLATFORM -DQT_THREAD_SUPPORT -D_REENTRANT -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -O2 -Wformat-security -Wmissing-format-attribute -Wno-non-virtual-dtor -fno-exceptions -fno-check-new -fno-common -MT k3bmonkeydecoder.lo -MD -MP -MF ".deps/k3bmonkeydecoder.Tpo" -c -o k3bmonkeydecoder.lo k3bmonkeydecoder.cpp; \
then mv -f ".deps/k3bmonkeydecoder.Tpo" ".deps/k3bmonkeydecoder.Plo"; else rm -f ".deps/k3bmonkeydecoder.Tpo"; exit 1; fi
In file included from k3bmonkeydecoder.cpp:16:
k3bmonkeydecoder.h:19:29: error: k3baudiodecoder.h: No such file or directory
k3bmonkeydecoder.cpp:23:30: error: k3bpluginfactory.h: No such file or directory
k3bmonkeydecoder.h:23: error: expected class-name before '{' token
k3bmonkeydecoder.h:24: error: ISO C++ forbids declaration of 'Q_OBJECT' with no type
k3bmonkeydecoder.h:26: error: expected ';' before 'public'
k3bmonkeydecoder.h:30: error: expected ',' or '...' before '&' token
k3bmonkeydecoder.h:30: error: ISO C++ forbids declaration of 'KURL' with no type
k3bmonkeydecoder.h:34: error: ISO C++ forbids declaration of 'K3bAudioDecoder' with no type
k3bmonkeydecoder.h:34: error: expected ';' before '*' token
k3bmonkeydecoder.h:40: error: expected class-name before '{' token
k3bmonkeydecoder.h:41: error: ISO C++ forbids declaration of 'Q_OBJECT' with no type
k3bmonkeydecoder.h:43: error: expected ';' before 'public'
k3bmonkeydecoder.h:47: error: 'QString' does not name a type
k3bmonkeydecoder.h:52: error: 'K3b' has not been declared
k3bmonkeydecoder.h:52: error: expected ',' or '...' before '&' token
k3bmonkeydecoder.h:54: error: expected ',' or '...' before '::' token
k3bmonkeydecoder.h:54: error: ISO C++ forbids declaration of 'K3b' with no type
k3bmonkeydecoder.cpp:32: error: expected constructor, destructor, or type conversion before '(' token
k3bmonkeydecoder.cpp:46: error: expected constructor, destructor, or type conversion before '*' token
k3bmonkeydecoder.cpp:53: error: prototype for 'bool K3bMonkeyDecoderFactory::canDecode(const KURL&)' does not match any in class 'K3bMonkeyDecoderFactory'
k3bmonkeydecoder.h:30: error: candidate is: bool K3bMonkeyDecoderFactory::canDecode(int)
k3bmonkeydecoder.cpp: In member function 'bool K3bMonkeyDecoderFactory::canDecode(const KURL&)':
k3bmonkeydecoder.cpp:57: error: invalid use of incomplete type 'const struct KURL'
/usr/include/kde/kdebug.h:36: error: forward declaration of 'const struct KURL'
k3bmonkeydecoder.cpp: At global scope:
k3bmonkeydecoder.cpp:81: error: expected `)' before '*' token
k3bmonkeydecoder.cpp:95: error: no 'QString K3bMonkeyDecoder::fileType() const' member function declared in class 'K3bMonkeyDecoder'
k3bmonkeydecoder.cpp:101: error: 'bool K3bMonkeyDecoder::analyseFileInternal' is not a static member of 'class K3bMonkeyDecoder'
k3bmonkeydecoder.cpp:101: error: 'K3b' has not been declared
k3bmonkeydecoder.cpp:101: error: 'frames' was not declared in this scope
k3bmonkeydecoder.cpp:101: error: expected primary-expression before 'int'
k3bmonkeydecoder.cpp:101: error: initializer expression list treated as compound expression
k3bmonkeydecoder.cpp:102: error: expected ',' or ';' before '{' token
In file included from /usr/include/c++/4.2/bits/locale_facets.tcc:43,
from /usr/include/c++/4.2/locale:46,
from /usr/include/c++/4.2/bits/ostream.tcc:46,
from /usr/include/c++/4.2/ostream:572,
from /usr/include/c++/4.2/iterator:70,
from /usr/share/qt3/include/qvaluelist.h:51,
from /usr/share/qt3/include/qmap.h:49,
from /usr/share/qt3/include/qmime.h:46,
from /usr/share/qt3/include/qevent.h:48,
from /usr/share/qt3/include/qobject.h:48,
from /usr/share/qt3/include/qconnection.h:45,
from /usr/share/qt3/include/qmetaobject.h:45,
from k3bmonkeydecoder.moc:12,
from k3bmonkeydecoder.cpp:212:
/usr/include/c++/4.2/typeinfo:41: error: expected declaration before end of line
make[3]: *** [k3bmonkeydecoder.lo] Error 1
make[3]: Leaving directory `/home/daniele/k3bmonkeyaudioplugin-3.1/src'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/daniele/k3bmonkeyaudioplugin-3.1/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/daniele/k3bmonkeyaudioplugin-3.1'
make: *** [all] Error 2
