Maggio 22, 2012, 02:29:35 am *
Autore Discussione: [RISOLTO]HP color laser jet 2600n  (Letto 1968 volte)
« inserita:: Luglio 19, 2008, 03:54:04 pm »
Ho dei probblemini con la stampante, anche se lo già cofigurata e lo anche usata in linux con; "Gestione Stampa" in "Strumenti di Sistema", ma a volte funziona e a volte no  Occhi al cielo
La stampante è questa:
http://search.hp.com/gwitita/query.html?lang=it&submit.x=8&submit.y=9&qt=Color+Laserjet+2600n&la=it&cc=it
Qualche Output utile  Occhi al cielo:
Parte del'output lsusb -vv:
[root@localhost fenix]# lsusb -vv
Bus 001 Device 004: ID 03f0:2e17 Hewlett-Packard
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x03f0 Hewlett-Packard
  idProduct          0x2e17
  bcdDevice            1.00
  iManufacturer           1 Hewlett-Packard
  iProduct                2 HP Color LaserJet 2600n
  iSerial                 3 F93BWEK
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower               98mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         7 Printer
      bInterfaceSubClass      1 Printer
      bInterfaceProtocol      2 Bidirectional
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0001
  Self Powered
E anche:
Bus 001 Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
prima funzionava ora non più, avra perso le impostazioni?  Occhi al cielo.
Grazie, a dopo Sorriso.
« Ultima modifica: Luglio 23, 2008, 03:31:54 pm da michele.p » Registrato
« Risposta #1 inserita:: Luglio 20, 2008, 06:39:45 pm »
...il sito di riferimento per le stampanti in GNU/Linux è;
http://openprinting.org/
La tua stampante;
http://openprinting.org/show_printer.cgi?recnum=HP-Color_LaserJet_2600n
è data per funzionante (anche se con due pinguini su un massimo di tre  Ghigno ).
Cosa intendi; a volte funziona altre no?...in sostanza alcune volte stampa e altre no?...oppure stampa sempre però alcune volte solo caratteri strani oppure lascia le pagine in bianco?
Prova a verificare se stai usando il driver che viene raccomandato nel link che ti ho riportato poco sopra (alias foo2hp).
« Risposta #2 inserita:: Luglio 21, 2008, 02:06:15 pm »
Grazie per questi link di riferimento  Sorriso, molto utili.
Ho installato il driver "foo2hp" come descritto, e si è installato bene ma la stampante non funziona, non'è la prima volta che installo la stampante, e prima funzionava pure  Che?!?, e adesso ho pure stampato la paggina di prova del cosi detto CUPS (Unix, Printer, System) un'interfaccia grafica (webrowser che pratticamente funziona con firefox) per la configurazione e tutto ok, mi dice che la stampante e stata aggiunta con successo e mi stampa detta "paggina di prova", ma vado per stampare un documento .ODT di office e sembra morta  Che?!?, se non fosse per il led dell'accenzione..., sembrerebbe che è spenta. Felice
Grazie e a dopo Sorriso.
« Risposta #3 inserita:: Luglio 21, 2008, 10:06:31 pm »
...se ben ricordo usi diverse distribuzioni; non ti funziona su nessuna di esse oppure solo su qualcuna, e se così su quale?
« Risposta #4 inserita:: Luglio 22, 2008, 02:08:05 pm »
 Felice ho mandriva in due partizioni  Felice, una e KDE, l'altra GNOME (così ho i due ambienti grafici), perche di tutti gli OS che ho provato (inclusi quelli a pagamento) Mandriva e il meglio, e non mi stacherò di dirlo: COMPLIMENTI a i suoi svilluppatori (non sò se si dice così)Occhiolino.
Quindi, male per HP che non sia dovutamente aggiornata.  Indeciso.
Ricordo che una volta su Ubuntu funzionava ma parzialmente.
« Risposta #5 inserita:: Luglio 22, 2008, 11:34:23 pm »
...vai in Menù->Strumenti->Strumenti di sistema->Centro di controllo. Nel pannello di sinistra vai su Periferiche->Stampanti. A questo punto dal pulsante in basso "Modalità amministratore" entra in tale modalità, seleziona la stampante e rimuovila attarevrso il menù "Stampante->Rimuovi". A questo punto prova nuovamente a configurarla. Clicca sul menù "Aggiungi->Aggiungi stampante/classe" e segui il wizard. Quando ti verranno chiesti i driver seleziona quello suggerito da openprinting ovvero "foo2hp".
...facci sapere...
« Risposta #6 inserita:: Luglio 23, 2008, 02:51:24 pm »
Stampa!,  Occhiolino.
Grazie mille.
« Ultima modifica: Luglio 23, 2008, 03:31:29 pm da michele.p » Registrato
